Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ZZ4 camshaft
Thread: ZZ4 camshaft
  #19 (permalink)
Old 10-13-2012, 10:53 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Lt1 cam
Camshaft Specs (12551705): 205/207 duration @ 50*, .447/.459" lift, 117 Lobe Seperation Angle
This is the LT1 cam from the corvette with manual transmission.
The Camaro LT1 and impala/caprice LT1 got a different milder cam
3 different cams in the LT-1 motor depending on the car and trans used.
These 5.7 liter 10:1cr+++ high perf corvette Lt1 motors got a special high stall 2200stall converter.
and gears
That converter stalls about 1600 behind a lil 305.
not enough stall .
Go out in the driveway and stall test your converter against the brake.
I bet it cannot get past 1500rpm.
