ZZ4 camshaft - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 10-14-2012, 06:00 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Originally Posted by mafiacustomz View Post
i would also like to add the guy said the cam came out of a 80's camaro with the tpi 350 that is a zz4 right?
Any cam that idles the way you want your car to is going to make your car a total dog that is nothing but a big PITA to drive unless you do the things F-Bird '88 has been trying to tell you. You really should listen to him, the guy knows 305's.
  #32 (permalink)
Old 10-14-2012, 06:50 PM
Ok so lets say i go to a carb and add the zz4 cam so the computer is out of the way. How bad will my mpg go down i would say it gets 20 mpg highway now what would it be after.
  #33 (permalink)
Old 10-14-2012, 07:35 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Can I get into trouble if I disconnect any of the... — Yahoo! Autos
Emissions controls were first used by the factories in 1967, so buy yourself any make or model that's 1966 or older and install any rump-rump cam that you want to.
  #34 (permalink)
Old 10-14-2012, 08:11 PM
Hippie's Avatar
Realistically? It could end up in the single digits but probabaly low to mid teens. I have known SOOO many guys over the years that have done what you're wanting to do and turned decent running cars into total turds.
The ZZ4 cam doesn't even have that much of a lopey idle, even in a 305. I'm putting one in a 305 for my truck BUT I'm building the engine from the block up to make use of the ZZ4 cam with Vortec heads, flat top pistons, 9.8 to 1 compression, aftermarket intake, Tri-Y headers and my truck already has the torque converter and gears to make it work. I'm counting on NOT hearing much cam.
  #35 (permalink)
Old 10-14-2012, 09:02 PM
I dont care about emissions controls the only thin i still use on my car is the o2 sensor i already took off my smog pump and i dont have a MAF and my car runs great.
I guess i need to ask this now is their any bigger cam that will work with my stock computer if i have to do valve springs thats no big deal that is in a OE motor.
My stock cam is 178/194 @ .050, .350"/.385", 109* lobe seperation 112
  #36 (permalink)
Old 10-14-2012, 09:13 PM
Senior Curmudgeon
Wiki Edits: 326
That's what's wrong with America.
  #37 (permalink)
Old 10-14-2012, 09:30 PM
No thats what right with america freedom of choice my car runs alot cleaner thin most where i live. I keep my caprice tip top hot plugs good gas 289k on motor runs like a champ. I guess if you dont like that get out of the usa.
  #38 (permalink)
Old 10-14-2012, 09:40 PM
F-BIRD'88's Avatar
Yada Yada Yada
That cam is so small you can yank it right out without removing the lifters.
  #39 (permalink)
Old 10-14-2012, 09:46 PM
F-BIRD'88's Avatar
Yada Yada Yada
Try this "RamJet" Camshaft
GM part number 14097395 196° 206° @.050 .431-.451 109 LSA
Some spec info
http://67-72chevytrucks.com/vboard/s...d.php?t=255659
  #40 (permalink)
Old 10-14-2012, 09:56 PM
Senior Curmudgeon
Wiki Edits: 326
It's not about how clean your motor runs, it's about breaking the law. That makes you part of what's wrong with America. Nobody said that you have the freedom of choice to obey some laws and scoff at other laws that don't fit your lifestyle.
Moderators, don't get alarmed, I'm done on this thread.
  #41 (permalink)
Old 10-14-2012, 10:01 PM
i dont have them laws where i live they dont care in ky ive looked it up.
that cam 14097395 isnt computer controlled i thought it had to be.
  #42 (permalink)
Old 10-14-2012, 10:36 PM
F-BIRD'88's Avatar
Yada Yada Yada
Don't know what you are talking about.
The motor that that cam is from, has EFI
350 "RamJet" crate motor.
  #43 (permalink)
Old 10-14-2012, 11:51 PM
I know the ramjet is EFI but summit which has the cam says its not computer controlled i like the cam for $175 its sweet. If you say that cam will work thats what i will get and i would like to know what size valve springs i need and would a port and polish be a good idea.
  #44 (permalink)
Old 10-15-2012, 08:49 AM
Its guys like this that give guys like me with an 80s car a bad rap... *sigh*
  #45 (permalink)
Old 10-15-2012, 10:52 AM
how is that i dont have a 80's car its a 91 LOL
ZZ4 Camshaft experiences...My stock cam V/S ZZ4 Cam Calderone Engine 7 01-25-2008 07:53 PM
Zz4 unstable2 Hotrodders' Lounge 4 08-29-2006 12:34 PM
Zz4 unstable2 Engine 1 08-20-2006 07:09 PM
Zz4 Camshaft Sound NAIRB Engine 2 05-16-2006 08:29 PM
zz4 or not Eagle1 Engine 5 07-19-2004 11:34 PM
