The GM ZZ4 "hot cam" has more lift and more duration and is designed to work with 1.6 ratio rocker arms which add a little more lift. As an example the GM Parts Performance Fastburn 350 is rated at 385hp. Simply adding the "hot cam" kit raises the hp to 430.
Vince
