ZZ4 engine problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2011, 07:52 AM
ZZ4 engine problems
I have a zz4 in my 1941 ford. It was running perfect all last year. It is now back firing through the carb and exaust at idle. I have checked the counter weights and timing. It has a stock hei. The idle doesn't drop when I unplug the vacuum line? Could the vacuum advance be causing it to run bad? Help!
Old 05-07-2011, 09:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The vacuum advance won't change the idle speed unless it's hooked up to a manifold (not ported) vacuum source. If there's any chance the timing was changed, I'd check it w/a light to verify it's OK. If it sat long enough for the fuel to have evaporated out of the carb, there might be deposits that are plugging the jets/passages of the carb, and/or the air bleeds could be stopped up w/crud. I'd check for vacuum leaks while you're at it.
odd engine problems bonzipenguins Engine 12 01-10-2007 09:36 AM
engine problems 75scout2man Engine 1 08-29-2006 11:16 PM
Engine problems? 74_Chevy Engine 5 08-16-2005 07:04 PM
Engine Problems 305 or 350 CaMaRoMaN_79 Hotrodders' Lounge 6 10-14-2004 08:37 PM
engine problems dion Engine 5 07-26-2003 08:11 PM
