ZZ4 I have screwed up!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2004, 02:40 PM
Guest
Here we go.. changing plugs..angled plug heads on ZZ4..have 312 miles on it..why change of plugs..running rich and fouled them.. anywho.. while taking the plug out of #8, the socket got lodged on the header just as the plug was loose enough in the hole also to get crooked.. well, I screwed up the threads.. thought maybe I could just put new plug in and it would straighten back out.. I was wrong.. the plug is in but it looks crooked even tho it is sealed (apparently).. now I found out the plugs I put in are wrong anyway.. so they have to come out..
What do I do now? New head? take it to Chevy dealer and let them fix it?
Yeah I screwed up.. so lets get past that and tell what I need to do to get the thing right..
Thanks
Rob
Old 05-17-2004, 03:02 PM
USA1's Avatar
Put some grease on a tap and slowly, thread by thread, chase the threads. If you do a little at a time and keep lots of grease on the tap, you should be able to clean it up without getting too much debris in the cylinder. Cheer up, it could be much worse.
Old 05-17-2004, 04:01 PM
Just make sur ethe tap is going in at the right angle.
Old 05-17-2004, 07:50 PM
302 Z28's Avatar
Above suggestions will work, but also use an air nozzle with a tube extension to insert into the cylinder so you can pressurize the cylinder. Just about all aluminum scraps will be carried out.
Use NeverSeize on those threads.
Vince
