Zz4 identification - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2012, 10:36 PM
Zz4 identification
I was wondering if anyone can help me identify a gm crate engine? I bought this engine two years ago that the guy claimed is a 10yr old "never been run" zz4. It has all of the carictoristics of a zz4. Aluminum angle plug heads, plastic timing chain cover, block says "hencho de Mexico" ect. But the problem I see is every ware I've read says the stamp on the block must say zz4 and mine does not. Here is the number stamped in mine on the block near the water pump in front of the right cylinder head. 1M1221-2P04. Can anyone decode this for me?
Old 05-24-2012, 11:32 PM
cool rockin daddy's Avatar
Did you know that you could call up any GM dealer and they could look up that number?
Old 05-25-2012, 09:24 AM
I called my local gm dealer and the only number he could look up is the 8 digit casting number wich comes back as a zz block. The serial number I gave came back as built on dec 21st 2004. But he also said if it was a zz4 it should have that stamped at the end of it. Mine does not. Still don't know any more than I already did. Circle track engine maybe?
Old 05-26-2012, 07:48 AM
Greg T's Avatar
www.krusinklassics.net
What heads are on there? Chances are that if it has the L98 #463 heads it's probably the ZZ4. Normally "ZZ4" will be on the machine pad after the part number. It was on mine.
Old 05-26-2012, 11:08 AM
Heads are #10088113 cast under the right valve cover. I was also told that there should be a zz4 stamped after the serial number on the machined pad but mine does not. That's why I'm questioning wether its a tru zz4 or not.
Old 05-26-2012, 12:10 PM
Pretty clear that you don't. Heads don't have the right # and it doesn't have the zz4 stamp.
Old 05-26-2012, 02:24 PM
I looked up the head casing number is this website:
http://www.gmpartsdirect.com/perform...CATID=671.html
Says its a 58cc corvette head. Isn't this the same size that were put on zz4's?
Old 05-26-2012, 10:20 PM
What is it you want us to say? You bought a crate engine from some guy who said it was a ZZ4. You didn't check the numbers before you laid down the cash TWO years ago. Are you trying to sell it? If you're going to use it, what does it matter? You've identified the heads. You can pull the pan and see what the bottom end is. It's easy enough to measure your cam lift. What exactly is it you need us to say about your mystery engine? I'm not getting it at all.
Old 05-26-2012, 11:40 PM
Greg T's Avatar
There's a slight misunderstanding here. The casting number is a 113 but the part number is a 463.
Old 05-26-2012, 11:54 PM
Just like to know what I'm putting in my car is all. This is my first engine install so I don't want to be telling people it's a zz4 if it isn't. Didn't think it would be that hard to decode if I had the serial number but even gm can't tell me what it is.
Old 05-27-2012, 01:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
How deep is the oil pan? If it has an originally-installed deep sump pan (~ 7" deep; 7-8 qt., w/a kick out on the side), and stock-style v-covers w/two breathers on the driver side, you prolly have a circle track "spec" engine used for racing where the engines are basically run as-is. Some had tamper-proof hardware, some not. Look for bolts or tags that look different in some obvious way- I do not know exactly what was done to make them tamper proof (or more like tamper evident, i.e. it'll show if you jacked w/the engine to get inside it), but something will be obvious if it's one like that. If it's not a tamper proof engine, there will be no such thing, but it also won't say "ZZ4", either.
Otherwise you may have a clone of a ZZ4 engine. I would want to look closely at the cam to see if it was a flat tappet or hydraulic roller (or solid if aftermarket/non- GMPP crate engine), and to see what the numbers on it were. With that info and finding the deck height and the piston volume, the compression can be calculated (the nominal head volume is known). Knowing the CR will tell you if the cam is compatible.
ZZ4 Camshaft experiences...My stock cam V/S ZZ4 Cam Calderone Engine 7 01-25-2008 08:53 PM
Zz4 unstable2 Hotrodders' Lounge 4 08-29-2006 01:34 PM
Zz4 unstable2 Engine 1 08-20-2006 08:09 PM
Will Dominator be too much for ZZ4? shockers69 Engine 4 07-27-2004 10:38 AM
zz4 or not Eagle1 Engine 5 07-20-2004 12:34 AM
