-   -   zz4 intake (http://www.hotrodders.com/forum/zz4-intake-220393.html)
rod kent 06-11-2012 09:01 AM
zz4 intake
Hi,I am installing a zz4 small block that I purchased as a new crate motor in 2009. My question is can I install about any small block intake on it? I want to get a dual. Quad setup, but most catalogs just list through 86 or so. I am headed to Pomona and would like to know what to look for. Thanks
DoubleVision 06-11-2012 09:17 AM
ZZ4 engines came with Aluminum heads that have the standard 12 bolt pattern like the generation 1 small blocks did, so getting a dual quad intake for it is easy. So when picking a intake any of them for a pre 1986 style head will work.
rod kent 06-11-2012 10:06 AM
thanks!!
That helps a lot, thanks
