ZZ4 questions
I am installing a ZZ4 and have some questions.
First off, the distributor out of the crate was off by 180 degrees. I set the number 1 up for top dead center and put the distributor back in to fix the problem. The instructions with the motor state to run 12 degrees initial and 34 total. The guy at the GM dealer said I need to watch total as he has seen some distributors run up to 45 degrees which melts pistons. Is there anyway I can check total advance prior to firing the engine other than putting the distributor on a machine? I do have an Accel adjustable vacuum advance. Should I intall this instead of the "factory" can? Secondly, I had overheat issues with the old motor. I had a Be Cool 2 row vertical radiator, mechanical fan, shroud, and 2370 cfm Zirgo puller. With a 180 thermostat it would run 192 going down the road and sometimes peg the temp gage at 240 in stop and go traffic. On the new motor, I have installed a Stewart Stage 2 pump, fan shroud, overdrive pulley, a 17" flex fan with 7 blades. I also have a Griffin cross flow radiator on the way. I have been reading the threads on thermostatic fans and electric fans. I'm taking the position that the electric fan is insurance. The clutch fan issue is still up for grabs in my book. I'm not really concerned about noise if I can cool the thing. The coolant will be 50/50 anti freeze/water. I won't be using the pink stuff as a friend with a similar set up had all kinds of leaks with the pink stuff and everyone he talked to told him to drain and use the green stuff. All the leaks stopped when he changed from pink to green. Straight water is not an option due to the aluminum corrosion/electrolysis issue and the need to store the car in sometimes sub zero conditions. Any help on the timing issue or cooling one of these motors would be a big help. Thanks Oldstreetrodder |
I always take the distributor OUT anyway to prime the oil pump and lube the engine prior the start up anyway. Overheating is usually one of these...... 1) lack of cooling capacity 2) lack of air flow 3) too lean .....carburetor 4) timing 5) no vacuum advance 6) under hood ambient temperatures......no way for the heat to escape.. ![]() I have installed quite a few Chevrolet crate engines.......for myself and others. I have the ZZ430 pictured above in a 32 Ford roadster...with no overheating issues....but I have a Z series Walker radiator (4 row ), and 7 blade 18 inch fan ( clutch type ) and a 25 Vent hood on my car. I have the Jet Hot coatings on my exhaust.......and room at the rear of the engine compartment to let the air out.... You have seen how well the hood helps the engine cooling in this photo......almost like not having a side panel on the hood. What type of car is the ZZ4 in ? Which carburetor are you using ? Do you have a vacuum source.........full time? I always use a good Robert Shaw thermostat.....not A/C Delco......or a cheapie I always use GM pulleys....the ratio is right.....the aftermarket stuff is not always correct..... I like a transmission cooler.........separate from the radiator..... I NEVER use a electric fan........I believe they impede air flow......when I have a good mechanical fan... I run just enough anti-freeze ( green ) to insure no freezing...50/50 is not the best ratio IMHO......the less you have to use.the better......has been my experience...... DEUCE.....
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
DEUCE
re: ZZ4 questions
The engine is in a '56 Chevy 210 two door wagon.
I did pull the valve covers and checked timing. The mark on the dampner was right on. I also pulled the distributor and pre-lubed the motor. The carburetor is a Demon that is supposed to be calibrated for the ZZ4. The radiator is a two row, 1 1/2 inch tube, cross flow from Griffin. The fan is a 7 blade flex fan from Perma cool. I am using a Stewart stage 2 pump with a 180 degree Robert Shaw thermostat from Stewart. The water pump pulley is from Zoop's and is about 5 1/2 inches in diameter which is 1 inch smaller in diameter than the stock pulley. I will be using coated Sanderson block hugger headers and 2 1/2" exhaust. The tranny cooler is separate from the radiator but I will probably run through the remote cooler into the radiator and then back to the transmission. The remote cooler was warm to the touch with the other motor. I haven't fired the thing yet as I am waiting for the radiator to arrive. I noticed that you are using a water pump riser on the ZZ430. |
| ZZ4 with Victor jr. Heads | Bud911 | Engine | 8 | 05-23-2006 10:03 AM |
| Interior -- Common Questions | Jon | Interior | 0 | 02-12-2004 04:38 PM |
| Questions, questions, questions? | slider in wa | Transmission - Rearend | 2 | 09-27-2003 02:01 PM |
| Nuts, Bolts and stripping questions | Bluepen | Body - Exterior | 5 | 08-14-2003 05:15 PM |
| ZZ4 Camaro | Chadman | Engine | 5 | 04-03-2003 02:15 PM |
