zz4 sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2010, 09:44 PM
zz4 sbc
i have a question , i just purchased a used zz4 sbc, i see it has 305 heads from a 87 88 camaro...i also just found a set of gm 23 degree aluminum heads
trying to put together a 55 chev truck..want a streetable hotrod..wont be a daily driver for sure...i just would like advice on which heads to use.
by my internet research it looks like the 305's will give it 11.1 compression
also should i use the zz4 cam or can you recommend a new cam with the aluminum?
the heads are supposed to have the heavy springs, what roller rockers lift should i have 3/8 studs?
thanks for any advice you can give me
i am a newbe at hotrodding
i am looking for a street/strip rod
alitakjack
Old 10-07-2010, 12:27 AM
zz4 numbers head numbers
the head numbers are 14101081, the block numbers 10243880
I also found a red and silver sticker glued to the block says remanufactured number 548767
probably was a crate motor that was rebuilt with vortec heads 4 bolts down center valve cover , is hard to say whats inside without dismantling
what do you think?
ZZ4 cam for street motor??????'s mupton Engine 3 07-23-2009 10:23 PM
ZZ4 Camshaft experiences...My stock cam V/S ZZ4 Cam Calderone Engine 7 01-25-2008 07:53 PM
ZZ4 Cam in Vortec Motor? 307malibu Engine 14 10-23-2007 10:40 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
installing dipstick SBC ZZ4 accobra Engine 1 02-28-2002 09:52 AM
