Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ZZ4 Short Block Info
Old 12-15-2005, 04:42 PM
Deuce Deuce is offline
ZZ4 heads have 58 cc's ...yours are larger so less compression
The ZZ4 cam is somewhat mild ....your intake and 3310 carb are better suited to a HIGHER RPM than what the ZZ4 cam is.
Lower compression and not enough camshaft and a carb that flows a good bit ......you be the judge......
