Your choice of IFS kit. Free speech auction: win your choice of Mustang II IFS kit, donated by Progressive Automotive.
Retail value: $1,159.00
Current high bid: $100.00
Click here for details, or to place a bid.
All auction proceeds go to support the legal fund to defend against the frivolous lawsuit filed against us by Streetbeasts.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 04-04-2002, 03:15 PM
fred56 fred56 is offline
Question Power steering conversion
I have a 1956 Ford w/351W and C-4 trans. I currently have the standard steering and since it steers like a truck I would like to put in a power steering unit that would clear the headers. I'm so close (1/8") that the grease wants to turn to oil and leak out the box. Anyone have ideas? I also would like to go to disc brakes on the front. Anyone with an idea?
Thanks. <img src="confused.gif" border="0">
Old 04-09-2002, 07:06 AM
snakejake snakejake is offline
Post re: Power steering conversion
why not consider using a mustang power rack? Have seen these used on street rods. since you have the 351 using the ford pump and serpentine belt would be simple. mounting the rack to the cross member would be the most diffcult part and maybe tie rod ends. food for thought?
Old 04-09-2002, 01:18 PM
Kansas - Thanks for the idea. I thought about it and I think I'll look into it.
Old 10-24-2003, 05:03 AM
billman's Avatar
billman billman is offline
The most common solution to the power steering solution is to swap in the complete Mustang II front subframe. Believe it or not, you can cut the frame on your '56 and the Mustang II will match the frame perfectly. Measure where to cut to maintain the same wheelbase. This way, you get a power front rack, disc brakes, a front mid-coil suspension and lower the ride height about 2 inches, not to mention a V-8 compatible engine mount.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
