Your choice of IFS kit. Free speech auction: win your choice of Mustang II IFS kit, donated by Progressive Automotive.
Retail value: $1,159.00
Current high bid: $100.00
Click here for details, or to place a bid.
All auction proceeds go to support the legal fund to defend against the frivolous lawsuit filed against us by Streetbeasts.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 05-30-2002, 10:42 AM
girdnerg girdnerg is offline
Post disc brake conversion
Hello everyone,
I have a 62' Buick Special that I would like to modernize the 4-wheel drum brakes to disc-drum or disc-disc. It currently has 4-lug non-self adjusting drums. This vehicle is a unibody and the entire front suspension is held in with 3 large bolts. This seems like a perfect car for the aftermarket to make a bolt-in replacement for, but I cannot find any. So, if anybody has an idea of what disc brake spindles will interchange or a kit made by someone, PLEASE HELP, because this thing is dangerous to drive in today's traffic. I would also like to change the stock rear-end since parts are hard to find and expensive when I do and the front end will eventually have five lugs.
Thanks,
Rob
girdnerg@nsuok.edu
Old 06-03-2002, 08:44 AM
Dave E Shank's Avatar
Dave E Shank Dave E Shank is offline
Post re: disc brake conversion
Rob: Check Master Power Brakes www.MPBrakes.com or 888-251-2353. They manufacture kits for all applications DAVE E SHANK davesr@trianglesalesusa.com
Old 06-03-2002, 10:37 AM
Thanks Dave, you are right about mpbrakes, but for $1000 or so, I was hoping to find a donor car with all the parts not just having a bracket welded onto my stock spindles. Plus this does not address the 4-lug drum brakes in the rear. Also, parts for this rare car are getting very hard to find and extremely expensive so I would like to upgrade to parts I can actually buy at the local parts store.
Old 06-03-2002, 05:46 PM
WoodsEdge's Avatar
WoodsEdge WoodsEdge is offline
MP will sell you the basic kit, which will be bolt on brackets, and possibly sleeves for your spindles for bearing to fit. They will give you year and part numbers for rotors, calipers, master cyl. pads, and any thing else you need. That way you can use parts from a doner car. I've done this a couple times, came out cheap. Master Power is one of the best co. I have done bus. with. They don't mind answering your questions, and I've had quite a few. Jack
Old 06-03-2002, 07:23 PM
Lou's Avatar
Lou Lou is offline
I have the brackets to convert the rear to disc. I think I have the stuff to convert the front also
Old 06-05-2002, 07:14 AM
Lou that sounds great about the front disc brakes, could you be more specific. As for converting the rear, the last time I bought an axle bearing, I couldn't even get two of them to do both sides at the same time. So I think I will just change the entire rear-end, besides I want to get away from the 4-lug bolt pattern and use something more modern.
Old 06-06-2002, 09:10 AM
F-1Rodder's Avatar
F-1Rodder F-1Rodder is offline
Take a look at the answer that I gave to 58Delray about his brakes.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
