Early Hemi rocker shafts Hotrodders.com Free Speech Parts Auctions
Bid on a part, or auction one off -- help us defend against a frivolous lawsuit, and protect free speech online.
Click here for details.
Parts currently up for auction: 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, Early Hemi rocker shafts, "Power Rods" billet air cleaner top.
Model A Ford headlights
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 07-18-2002, 10:06 PM
toxin toxin is offline
Post must II fr. end into 49 chevy
Is there any reason why you cant just use a stock must II cross member with some kind of welded brace instead of using a kit? Im wanting to put disc brakes and mustang steering in a 49 chevy fleetline. The width is damn near identical and when I was a kid a saw a few shade tree rods with must II front ends welded straight to box steel rails. Oh well, I figured id ask some folks who know more than me. Thanks
Old 07-19-2002, 05:58 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Gassers were best!
Post re: must II fr. end into 49 chevy
I've done two of 'em, one in a '36 Pontiac 4dr sedan and one in an award winning '42 Willys puckup with a tilt up nose so you know it ha to look right. Don't know what you mean by "welded brace" but the x-member goes just like it looks like it should and trailing arm brackets from the MII are bolted to the frame with some easy modification. Biggest mistake people make is to weld a bracket on the frame rails for the trailing arm. I am on a mission to point out broken trailing arm brackets to unsuspecting rodders at rod runs.
That being said, junk yards rule! I will never buy a kit for anyhting I can salvage out of a junkyard! I am into hot rodding not kit car building.
Send me your email address and I will send scans of a couple of tech articles that show step by step instructions for this installation.
Old 07-23-2002, 08:59 PM
Fred Byam Fred Byam is offline
Cool re: must II fr. end into 49 chevy
Willys36,
Send me those articles, too. I have a Mustang II front end to install onto a 1935 Ford Sedan. I got it on eBay with a (Heidts?) cross-member from a '32 Ford. It hasn't arrived yet, so I haven't checked dimensions yet to see how close the cross-member matches my frame. I'll be using a small block chevy with Turbo 350. Thanks.
fredbyam@swbell.net
Old 07-24-2002, 06:05 AM
Gassers were best!
Fred; My articles apply to installing a stock Ford X-member. They wouldn't be much help in installing an after market unit. Those have instruction manuals (or you can probably request one from the manfacturer if the one you got is missing).
Old 07-24-2002, 09:38 AM
Willys36,
Thanks, sometimes the wrong information is worse than no information. Since this crossmember I'm getting is from a '32, I don't know if I'll even be able to adapt it. If not, I might end up looking for a stock cross-member instead of spending $600 on a new after-market one. If you could send the article just in case, it might be put to good use. If not, I might learn something anyway. (I'm a babe in the woods when it comes to suspensions) Thanks
Fred fredbyam@swbell.net
Old 07-24-2002, 03:42 PM
CARGUY's Avatar
CARGUY CARGUY is offline
i would like a copy if i can i hav a stock mustang II i want to put under my 53 chevy thanx carguy0@hotmail.com
Old 07-25-2002, 05:25 AM
Gassers were best!
Fred and carguy; I tried to send the articles to you last night and got unsent mail messages on both of you. Fred's mailbox is full and carguy's address in unrecognized. These take an hour to send so I need good addresses!!
[ July 25, 2002: Message edited by: willys36@aol.com ]</p>
Old 07-25-2002, 03:25 PM
CARGUY's Avatar
sorry i dont know what happened the address was correct its carguy0@hotmail.com [carguy zero] thanx again sorry about all the trouble
Old 07-27-2002, 09:34 PM
Willys36,
I got the e-mail, thanks for the perseverance. I don't know why you got a "Full Mailbox" message the first time. I check it regularly. I printed it out and will use it as an extra reference in my attempts. Thanks. fredbyam@swbell.net
Old 07-28-2002, 07:09 AM
Gassers were best!
Which one did you get? I sent two yesterday and got "can't deliver, size exceeds mailbox limitis" on both. Evidentally one snuck thru. I'll try shrinking file size to get it thru but resolution will suffer a little.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
