Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 08-17-2002, 03:57 PM
Frog120 Frog120 is offline
New Member
Talking brake changing
Would a 16 yr old punk kid with hardly any tools like me be able to change rear disc brakes on a 94 dodge intrepid?(yea i know..its no where near a hotrod or classic car, but its what im pushing right now). I have no prior experience changing brakes, but id like to learn one way or another (by trial and error, or from someone else) Any tips would be much appreciated
Old 08-17-2002, 04:28 PM
windmaster's Avatar
windmaster windmaster is offline
Post re: brake changing
I would say if you want to, you can without and trouble at all. It may take you 30-60mins, but the next time you will know how and be able to change them in 5. The only "odd" tool you may need is a C clamp...if that's odd. Have fun
Old 08-17-2002, 11:36 PM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
Exclamation re: brake changing
Be advised that the rear piston must be (turned) back into the caliper with a special service tool as it is on a ratchet for proper hand brake operation. You try to press it back in with a c-clamp and the ratcheting mechanism will be damaged costing big bucks.
You also have the option of buying rebuilt loaded calipers and they would just be a bolt on (but requires system bleeding).
You first to need to find factual repair information (shop/repair manual) and go from there.
Old 08-19-2002, 12:07 PM
windmaster's Avatar
hey...interesting point there. Are all newer cars with rear disc manufactured in this fasion? I hope you didn't take my advice. Sorry about that. Come to think of it I have never changed rear disc brakes ( only front ) didn't even think of e-brake mechanism working like this
Old 08-19-2002, 01:26 PM
New Member
Wink re: brake changing
Thanks for all teh advice..I was talking to my friend matt who knows a biut about cars and asked him if he could help me out. He said he had that service tool that u need to move the rear piston. He said if you move it slow, then you wont have to bleed it at all. I dont think im gonna try this one yet, Ill get someone who knows how to do it, and ill watch em
Old 08-19-2002, 02:45 PM
KULTULZ's Avatar
aka Duke of URL
 KULTULZ's barnstar
I didn't mean to scare you off but just bring up a point. If you get the proper service literature, the job isn't as difficult as you think and it is the only way to learn.
Sorry about that...
Old 08-21-2002, 02:13 PM
helrazr3's Avatar
helrazr3 helrazr3 is offline
im on a highway to hell
thats my advise to, get a service manual and read it through a few times before you dive in good luck
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
