Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 09-14-2002, 12:14 PM
ksm's Avatar
ksm ksm is offline
56 Chevy Truck
Post 50 chevrolet pickup
Will a 1950 chevrolet pickup body fit on a 1956 frame. Trying to stay as origanal as possible but wanted to get away from 216. 56 is a 235 with open driveshaft. thanks
Old 09-15-2002, 06:19 AM
New2theart New2theart is offline
New Member
Post re: 50 chevrolet pickup
May want to think about a driveline swap instead of body swap. The two trucks body mounts are different not to mention electrical, and other linkage hookups and swapping the driveline is not that difficult in these trucks. Your open driveline can be swapped and your 235 should bolt right up in the 50'. I have a 53 and I am putting a 55 235 in place of the tired 216. everything else will remain original drive line (Enclosed) Good luck, like to see some pics if you have them. <img src="graemlins/crash.gif" border="0" alt="[crash]" />
Old 09-15-2002, 08:10 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Gassers were best!
Th 56 has a totally different frame. Will be much easier to swap in the 235 (direct bolt-in) and install a late model Chevy truck rear end. Just need to make riser blocks for the spring mounts to put the rear at the right height and make a new driveline. Get one with 3:23 - 3:56 gears. Stock 50s Chevys came with 4:11s and such for cruising cow pastures!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
