Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 09-20-2002, 06:17 AM
caesarsfish caesarsfish is offline
Post 1928 chev coupe body installed on S-10
I have a decent '28 chev coupe and would like to put it on a S-10 frame. Looks like it is close to being the same, any advice. thanks Caesar
Old 09-20-2002, 09:02 PM
HotRodMan HotRodMan is offline
Post re: 1928 chev coupe body installed on S-10
I have never done this myself, but I have talked to several people who have done this at the car shows and they claim that it is relatively easy to do and the S-10 frame and suspension is the way to go. If you get the S-10 truck cheap, you could build a nice street rod for $10,000 where the average cost is closer to $30,000.
Old 09-21-2002, 05:04 AM
DragLinkscc's Avatar
DragLinkscc DragLinkscc is offline
why put a REAL hot rod body on a S10 frame. youll be the Kool guy at the car show who NEVER has a real hot rod because your driving a s10 with a cool topper?
why not use a model a frame or hell even the more popular deuce frame?
Old 09-21-2002, 05:06 AM
Owe and the 30,000 dollar hot rod? come on a kick *** hot rod can be built for under 10,000 any day. if you arent into BILLET WORLD. this is the day of low buck rods. look at the economy who can afford it besides the gold chainers
Old 09-21-2002, 06:16 AM
Seon's Avatar
Seon Seon is offline
Just use your stock frame. I've owned my '31 Chev 2dr Sedan since the '60's. I put in a '57 rear end and used the stock front axle. Drove it as a daily driver till the 80's and retired it. What I plan using the stock frame is to put a Heidt IFS, 9" Ford rear, GM crate engine & 700r4 trans. Then cruise my ***** off. BTW your '28 chevy frame is a lot beefer than a Model A ford. Good luck.
Old 09-27-2002, 04:06 AM
Chevydude Chevydude is offline
Way to go Ceasar!! I too am looking at the S-10 frame for a project car. I have a '62 Chevy II Wagon with a sagging stock front clip and was thinking about mounting the body on the S-10 frame for a start, along with the 350, trans & rearend!!
Old 10-01-2002, 10:38 PM
rusty9663 rusty9663 is offline
well i am in the same process with a 1950 Willys Sedan Delivery.It is the most common way to go up here and as said the $$$ The S10 will fit right to the tee for me. The only thing I have to do block the rear and put drop spindles on
sorry i have the same logo SEON
[ October 02, 2002: Message edited by: rusty9663 ]</p>
Old 10-20-2002, 11:22 AM
streetrod936 streetrod936 is offline
New Member
the s 10 will work with your 28 chevy, you can also channel it to your desired height look, dick dean did the same with a 32 ford back in the70s by putting the ford body on a datsun frame called it (the dotrod) try it you will like the ride, Al ....
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
