Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 10-09-2002, 02:38 AM
kruzerone kruzerone is offline
Question 51 Stude
I have a 51 Stude biz coupe that needs reframing.
The wheel base is 115 inches, and the Studes of this era are very narrow. What would be a good frame for this car? I have a 350, 350 turbo for it.
I need advice about framing this car.
Old 10-09-2002, 07:55 AM
pasadenahotrod pasadenahotrod is offline
Post re: 51 Stude
Not sure what exactly the term "reframing" means...but here goes.
1. If you mean your frame is rusted out, rotten, bent and unusable, I believe the frames for all Study passenger cars are about the same from 1947 through 1952. So find a crappy old 4door and grab the frame.
2. If you mean use the frame from some other make of car such as a late model Malibu or something, don't try it!
3. The best way to gain better front suspension, brakes, steering, etc. is to use a Pinto/Mustang II front suspension setup. Your rear suspension should be ok, just change the rearend to get tougher gears and better brakes. If the springs are flat, you can get them re-arched at any local spring shop for a nominal charge.
Best of Luck!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
