Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 10-21-2002, 05:54 PM
72chevyelcamino 72chevyelcamino is offline
New Member
Post 72 camino who do i buy front end kit from?
whos the best deal on front end kits?thanks
Old 10-22-2002, 12:55 PM
slider slider is offline
Post re: 72 camino who do i buy front end kit from?
We're (The kid is. I'm kibitzing) putting in a PST kit in a 70 C10. It seems to be pretty complete and the price was in the $180 range. Everything so far fits and does what it's supposed to. Kanter has the same deal as does the outfit in Phoenix. I'm sure they're all the same parts.
Old 10-23-2002, 06:53 PM
chevy8298 chevy8298 is offline
You don't mention what kind of front end kit (OEM, polyurethane) or if you are just looking for bushings/ball joints/etc. or complete with sway bars, shocks, etc. However, I am in the process of installing a "G" Force kit from Performance Suspension Components that was very competitive in price and includes Energy Suspension poly bushings, Federal Mogul parts, Hellwig sway bars, and KYB gas shocks.
Good luck with your Elky.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
