Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 10-22-2002, 06:55 PM
SParkybo SParkybo is offline
Thumbs up 1960 el camino
Hey guys whazzup? I have a question regarding steering. I am wanting to install a later model power steering gearbox and I need to know if there is anyone experienced in doing this, that can give me some helpful suggestions. Also, what tilt wheel steering unit will work best. We prefer to keep things economical by going thru wrecking yards!!!(kid's first ride,tight budget) Thanks for taking the time to reply, Sparkybo
Old 10-24-2002, 05:59 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Post re: 1960 el camino
for a column try an early 70's chevy van column, tilt is hard to find but they are out there,get the right year and they don't have a column ign switch. try a late seventies malibu-montecarlo for a steering box.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
