Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 11-02-2002, 10:29 AM
slider slider is offline
Question Drum to Disc 70 C-10
We seem to have a bad hub on the kid's pickup and the local pull-your-parts doesn't have one. So unless one of you have a good 6 lug 2WD hub I need to get some info on going to a 71/72 disc brake changeover.
The last time this was done by us many moons ago, one truck was in the yard and the other in the shop about 20 feet from each other. We just started at the frame, pulled the entire knuckle and bolted it on the older truck. Snagged all the lines, master cylinder 'n' such and swapped them out as well.
Being as we just re-did the entire front end with a PST kit, which is how we found the bad hub, does anyone have experience simply swapping the spindle instead of the whole knuckle assembly?
Whew. Thanks in advance.
Old 11-02-2002, 06:15 PM
mooneyes4b mooneyes4b is offline
Post re: Drum to Disc 70 C-10
i did my 70 and used 80 spindles..also had to use the 80 steering linkage, calipers and hoses..used 71/72 balljoints..so youll at least have to replace the ball joints and tie rods
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
