Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 11-19-2002, 06:14 AM
BIGBLOCKSTANG's Avatar
BIGBLOCKSTANG BIGBLOCKSTANG is offline
New Member
Post disc brake conversion
has any one done or had any exp with doing a disc disc conversion i had disc drum on my 67 stang and i used a master cyl off a mark vii and i dont know how hard the pedal should be i have bleed the brakes several times also i am running big chevy calipers in the rear and small chevy calipers in the front i also have a porp valve any help guys thanks !!!!!!!!!!!!!!
Old 11-19-2002, 07:08 AM
brit 56belair's Avatar
brit 56belair brit 56belair is offline
Talking re: disc brake conversion
Brake pedal should be solid and with little pedal travel without the engine running, when runing the pedal should fall away as the servo works.
Old 11-19-2002, 11:10 AM
New Member
Post re: disc brake conversion
what would keep the pedal from getting hard i dont have a booster do i need one ? i bled them several times
Old 11-21-2002, 02:15 PM
appleknocker's Avatar
appleknocker appleknocker is offline
Did you bench bleed the master cylinder? You may still have some air trapped some where in the system. Bench bleeding is important to do, saves lots of hassles and agravation.
I use an old master cylinder cover with a valve stem weled the the top. Just put a little air pressure, say about 3 pounds and let the air force fresh fluid through the system.
Old 11-22-2002, 06:07 AM
New Member
I have come to relalize i think it the pads and yes i built my own pressure bleeder out of a garden sprayer and an extra top i think the pads i was using were worn at an angle and that caused the soft pedal thanks guys.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
