Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 11-30-2002, 05:18 PM
cuda66's Avatar
cuda66 cuda66 is offline
Post 1952 brakes suck
I have a 1952 ford f1 pickup and it is all original. I need to know if anyone has ever done a brake swap to discs. You can tell that the truck was built in 1952 not only by its looks but by the way it makes you feel when you try to stop it. I dont mind mods but im not much of a welder. Does anyone have any suggestions?
Old 12-01-2002, 03:42 AM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
Arrow re: 1952 brakes suck
-Master Power Brakes Conversion-
-Courtesy...Duke of URL
Old 12-01-2002, 06:23 AM
jwcnj45's Avatar
jwcnj45 jwcnj45 is offline
Post re: 1952 brakes suck
Before I upgraded suspensions on my F1 I did a disc brake conversion on it. It was a big improvement over the old drum brake set up. I used a conversion kit from ECI at the time and also switched over to a dual master cylinder. If you switch over to the disc set up and leave the master cylinder under the floor boards make sure that you install residual valves in the lines. Use 2# in the front line and 10# in the rear line.
Old 12-02-2002, 06:22 AM
Biggarmike's Avatar
Biggarmike Biggarmike is offline
Chief Procrastinator
You've got great brakes in your F1. (compared to my 36 Lincoln!)
Old 12-03-2002, 02:51 PM
chrome_ashes chrome_ashes is offline
If you've got the time to research it, you can do it without a kit. From what I've seen, it looks like the Ford kits are using a rotor from another vehicle that has an integral hub. They typically bolt up to the stock spindles. The only thing you have to figure out is the caliper bracket. I know that a lot of companies selling the disc kits for Chevys will sell just the brackets, which saves you some cash. ...and you don't even have to weld anything
So talk to some people at a car show who have done the swap and see what rotors they are using or make some measurements and head to your local junkyard and you're well on your way.
If that sounds a bit too time-consuming, you can also check out :
<a href="http://www.classicperform.com/" target="_blank">http://www.classicperform.com/</A>
Old 08-17-2005, 09:49 PM
our52ford our52ford is offline
1952 Ford F1 Suspension and Brakes
This is my first restoration. My F-1 has original front end suspension. A 289 and automatic transmission from a '66 Mustang was installed by a previous owner. I'm thinking we should install IFS, as well as disc brakes, and possibly move master cylinder to the firewall.
Does this make sense?
I have seen there are several kits available for this conversion, but I was wondering if there is a reasonable way to accomplish this by cannabilizing a later model vehicle.
Any thoughts? thanks. our52ford
Old 08-17-2005, 10:20 PM
Lou's Avatar
Lou Lou is offline
Our 52 Ford: A Friend Of Mine Is Doing Some Chassis Work On A 53 Ford Pickup. The Guy Went And Changed His Mine On The Front End. From Straight Axle To Mustang 2. The Straight Axle Has Never Been On The Road. It Is A Eci Disc Brake Axle Springs The Whole Shooting Match. The Guy Wants To Get Rid Of It. If You Want I Can Ask What He Wants For It. If You Want It Call Me 980 521 0175 Lou
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
