Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 12-03-2002, 06:23 AM
timothya8 timothya8 is offline
Post Volare clips
On the above subject, does anyone have positive/negative experience with a Volare mated to a 1954 Dodge Coronet?
Old 12-03-2002, 05:16 PM
pray9123's Avatar
pray9123 pray9123 is offline
New Member
Post re: Volare clips
Would a '53 Plymouth Cranbrook qualify? I cut the front portion of my frame off and mated the '78 Volare k-member on using square tubing and the four original mounting tabs on the member. Pretty smooth operation, just check, double-check, and triple-check to make positively sure you are perfectly lined up. Front to back in the fender wells, side to side, and no twists or angles. If YOU line everything up properly, the alignment guy can square your wheels to the road.
If you want to ride low but still ride smooth, raise the member up to the middle of the frame. My k-member is sitting directly under the frame, and I wish I had gone another inch or so higher. My guesser was off.
Phillip
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
