Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 12-16-2002, 02:25 PM
JAY221 JAY221 is offline
New Member
Post BUMPSTEER
I have a 60 Ranchero with the original(63 V8) aframes still in it. I have mounted a Buick Skylark rack pinion in it at this point. Once I get everything back in it such as Motor/Tranny & all accessories it is my understanding that I should try to achieve a bottom aframe that is level with the ground to minimize bumpsteer. Am I on the right track or at the wrong station? Now with the front end skyhigh the bumsteer is horrible. Thanks for any advice/opinions, Jay
Old 12-16-2002, 03:33 PM
Lash Lash is offline
Cool re: BUMPSTEER
Jay, When you use a rack on an independent front end : If you make a straight line between were the top arm and bottom arm pivot the rack tie rods have to pivot in that line. If there close you might get away with it. If not it will be bumpsteer big time..........Lash <img src="graemlins/pain.gif" border="0" alt="[pain]" />
Old 12-16-2002, 03:42 PM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Gassers were best!
Post re: BUMPSTEER
As lash says, it is important to have the flex joints on the steering gear in line with the axis of the pivot on the lower A-arm and the tie rods on the rack parallel to the line between the lower ball joing and the lower A-arm pivot axis. As long as you have it set like that, it shouldn't have significant bump steer even if the front end is high in the air.
Old 12-18-2002, 04:19 AM
New Member
Post re: BUMPSTEER
Thanks guys, I believe I am on the right track. Later, Jay
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
