Your choice of IFS kit. Free speech auction: win your choice of Mustang II IFS kit, donated by Progressive Automotive.
Retail value: $1,159.00
Current high bid: $100.00
Click here for details, or to place a bid.
All auction proceeds go to support the legal fund to defend against the frivolous lawsuit filed against us by Streetbeasts.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 12-25-2002, 06:40 PM
femadorob420 femadorob420 is offline
Post FORD PINTO
Im trying to figure out how to go about changing my pinto from 4 lug to 5 lug and putting disc brakes up front.Will I have to have a power brake booster for the front discs?Helps Appreciated.
Old 12-25-2002, 07:30 PM
Deuce Deuce is offline
CURMUDGEON / MODERATOR
 Deuce's barnstar
Post re: FORD PINTO
You must have a early Pinto with the 1600 engine and drum brakes.
There are kits to convert the 74 up cars but I am not familar with a way to do a early drum brake car.
The spindles and a arms are also different so no help there.
A possible solution COULD be to use a Granda spindle. I heard a fellow say he did it...... but I have not done it and cannot in all fairness say will might work. I heard it at a cruise in from a fellow I do not know.......so........
Rat Rods are for those who cannot build a real Hotrod ...
Old 12-26-2002, 04:46 AM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
Post re: FORD PINTO
The easiest way to go about it is to find a disc brake setup off a 71/72 and remove the parts (spindle-rotors calipers-master cylinder-proportioning valve-etc.) and have the front rotors (and rear axles/drums) drilled for five lug. Manual disc is usable.
Step up would be to find spindles off of 74/ PINTO or MUSTANG II and mount a GRANADA rotor (11"). Custom caliper brackets can be bought (or fabbed) to fit either a FORD or CHEV caliper.
Old 12-27-2002, 01:11 PM
48fordnut's Avatar
48fordnut 48fordnut is offline
Post re: FORD PINTO
go to any street rodder mag and you will see an abundance of must. 2 parts for 5 lug, also ranger pick up, the early ones ,82/83 i've done several
Old 12-27-2002, 09:03 PM
PrimeMover's Avatar
PrimeMover PrimeMover is offline
Sittin' on top of the world...
Post re: FORD PINTO
Deuce Roadster, The good old Granada... I wonder if Ford knew just what kind of a great parts car they were about to come out with, when they designed that one..
What won't those Granada spindles fit?
A good friend of mine owns one of the nicest 58 Thunderbird Hardtops I know of. Steve was uneasy with the Bird's brakes from day one, and decided to go with a front disc set up and dual reservoir upgrade. The Granada spindles and calipers were a shoe-in for the Bird and the FOMOCO OEM master cylinder provided in the kit he found, bolted right up to the firewall's original mounting holes. If we would have known these spindles were off a Granada we could have easily saved around $350. Hind site's real cheap isn't it. Anyway, if those Granada spindles work as good on a Pinto as they do on a 58 bird, Femadorob's problems are over.
Good luck, keep me posted, I'm curious..
Old 12-28-2002, 03:19 AM
KULTULZ's Avatar
aka Duke of URL
 KULTULZ's barnstar
Arrow re: FORD PINTO
The GRANADA spindle is rear steer, whereas the PINTO/MUST II spindle is front steer. Therefore interchange is not feasible.
The retrofit of GRANADA spindles on an early FORD usually requires a change in the taper for the ball joints and/or outer tie rod ends. That is why they are priced that way in a kit.
Old 12-28-2002, 08:33 AM
PrimeMover's Avatar
Post re: FORD PINTO
KULTULZ - I must have been half asleep when I posted that one. <chuckle> Last winter I upgraded my older Chevy's suspension to Mustang II and just recently finished helping a friend with the Granada spindles on the Bird. Your right about the differences in taper sizes, both the Chevy's and Bird's kits came with hardened spacers to align the castle nuts with the cotter key holes.
All that holiday egg nog must have thrown me out of synk, Man.. Thanks for the wake up call. I hope Femer dosn't rush out to bone yard looking for Granadas.
Old 12-28-2002, 09:42 AM
KULTULZ's Avatar
aka Duke of URL
 KULTULZ's barnstar
Thumbs up re: FORD PINTO
[quote]Thanks for the wake up call. I hope Femer dosn't rush out to bone yard looking for Granadas.<hr></blockquote>
Hey! Don't worry about it...I have not met anyone perfect yet (well...maybe except for that blonde in BALTIMORE... :p ). If you will notice, I have given out incorrect info here also... <img src="graemlins/pain.gif" border="0" alt="[pain]" />
That's why we are here...to learn from one another.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
