Hotrodders Bulletin Board
#1
Hi guys,I have a 47 chevy sedan delivery I traded for.I know this subject has been hashed over before.I'm not new to streetrodding this is my 3rd project.The frame been stubbed once,the guy missed by 2 inches and way to wide.I looked back in the forum someone by premierpaintbody talked about this in May 2002,I was wondering has anyone done this? I've thought about restubbing,maybe using a S-10 stub that way keeping the body mounts,also looking for another frame and starting over maybe with a mustang 2.Right know going to start body work,research frame idea.I know using S-10 will have to shorten frame also rework body mounts.Thanks for thoughts.
#2
Usually I'm the first guy to try to talk someone out of doing a clip, however there are cases where it just makes sense to do one. Yours is just one of those cases.
You didn't say what clip the previous owner butchered the frame with but as long as you still have some good metal to weld to you should be in good shape. A friend of mine built a GMC pickup (same frame)a few years ago and used a Camaro clip that worked perfectly. You can see how he did it at the following link. <a href="http://purplesagetradingpost.com/sumner/sumnerindex.html" target="_blank">Sumner's Page</a> Good luck. Centerline <a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</a> [ December 27, 2002: Message edited by: Centerline ]</p>
Centerline HotRodsAndHemis.com "Political Correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end." |
#3
[quote]Originally posted by Centerline:
A friend of mine built a GMC pickup (same frame)a few years ago and used a Camaro clip that worked perfectly. You can see how he did it at the following link. <a href="http://purplesagetradingpost.com/sumner/sumnerindex.html" target="_blank">Sumner's Page</a> Good luck. Centerline <a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</a> [ December 27, 2002: Message edited by: Centerline ][/QB]<hr></blockquote> WRONG AGAIN ! ! Bill The sedan delivery uses a passenger car style frame. His is not a truck type (panel). A GMC pickup frame is not the same as his. It is a mistake that is done often As a former sedan delivery owner.... 1957 Chevrolet...... the easy way to keep them straight is panels have two rear doors and a truck front sheet metal. Sedan delivery has 1 rear door and car front sheet metal. .
I went to the school of hard knocks ... where the tuition is high but the retention is exceptional ! |
#4
You're correct, I missed that detail. However, if you're keeping score keep it correctly. It's 1 to 1. I was wrong on this one, but you were wrong on the Mustang II issue. Yea I know, your score card shows it differently.
Centerline <a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</A>
#5
Thanks Centerline and Duece,the frame is pretty good shape all and all.The clip I was told he tried to use some type of Cadillac?. Anyway I'm leaning towards a different clip to keep costs down, probably go to Chassis Eng. rear springs set up,I have a early Bronco 9inch laying around,I know the sedan delivery is a car frame,my sister got me a book for x-mas has alot of cars listed and wheel bases to compare it to 46,47,48 116inch wheel base,for instance so is a 1968,69 cheville 4 door.Anyway got a start.
#6
<strong>You're correct, I missed that detail. However, if you're keeping score keep it correctly. It's 1 to 1. I was wrong on this one, but you were wrong on the Mustang II issue. Yea I know, your score card shows it differently. Centerline <a href="http://www.hotrodsandhemis.com" target="_blank">http://www.hotrodsandhemis.com</a></strong><hr></blockquote> No score card kept here. I just want ZONK to have the information needed to make and base his decision. No slander or malice intended. That is why I put a smiley on the post. Everyone misses a point or has a different slant on a situation from time to time. Myself included. There has only ever been 1 perfect person on this earth and he just had a birthday Concerning the Pinto/Mustang II posts, please go back and read the newer ones...... the ones after you and I agreed to disagree. . [ December 27, 2002: Message edited by: Deuce Roadster ]</p>
#7
I haven't measured the width of a S-10 front yet,can a person go to narrow for a front clip? Just a question.
#8
[quote]No score card kept here. I just want ZONK to have the information needed to make and base his decision.
No slander or malice intended. That is why I put a smiley on the post. <hr></blockquote> I understand and no offence taken. Actually when I screw up I appriciate someone setting me straight, as my wife constantly reminds me. Centerline http://www.hotrodsandhemis.com
#9
Don't know about the s10 clip but am familiar with the camaro/nova. one thing to be aware of is if you get a front steer the steering box will be in the way of the radiator core suport if you keep it in the stock location. go to the rear steer nova and that will not be a problem. Other than that its a nice clip mod...GlennK
#10
[quote]Originally posted by zonk:
<strong>I haven't measured the width of a S-10 front yet,can a person go to narrow for a front clip? Just a question. ____________________________________ I suggest really looking at the rest of the work done to the delivery.....it may very well be done with the same level of compentance as the front clip. <img src="graemlins/sweat.gif" border="0" alt="[sweat]" /> <img src="graemlins/sweat.gif" border="0" alt="[sweat]" /> .
#11
Hi guys,the rest of the frame seems to be untouch still has original rear springs the guy tried to use some truck rearend,3inch lowering blocks(ouch)
the most part it is good and solid,I know nova clip will work might the camaro be to wide?Seems I have seen new front clips to use mustang2 pretty pricey. |
Back to top |
