Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 12-28-2002, 09:17 AM
Bill Ford's Avatar
Bill Ford Bill Ford is offline
Post Caliper Brackets for 8" Ford Rear
Do any of you guys know where to get a set of caliper brackets to mount 80-85 Eldorado rear calipers for 11' rotors on a small ford at a reasonable price? All the kit builders want "an arm and a leg" for just the brackets. I can buy the calipers and rotors locally. If I had a set of plans I could make them myself.
Old 12-29-2002, 11:31 PM
Studebaker Studebaker is offline
Post re: Caliper Brackets for 8" Ford Rear
Check on EBAY. There's a guy making and selling these brackets for about $80.00.
Old 12-30-2002, 02:16 PM
greybeard's Avatar
greybeard greybeard is offline
New Member
Hey Bill Ford,
I just looked in my Speedway Motors catalog and there are weld-on and clamp-on,then tack weld type caliper brackets ranging in price from $11.95 ea-$31.95 ea.
I used them on my 9" Cougar rear that I installed in my '48 Chevy. There is a picture of the brakes and rear end in my picture album.
Old 12-30-2002, 04:19 PM
Bill when you E-mailed me you didn't leave a return E-mail address. Message for Bill, To look for these Brake caliper brackets on EBAY, type in ( 8 inch ford brakes ) and they will pop up, they are $89.00 for the bolt on brackets that accept the Caddy calipers.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
