Your choice of IFS kit. Free speech auction: win your choice of Mustang II IFS kit, donated by Progressive Automotive.
Retail value: $1,159.00
Current high bid: $100.00
Click here for details, or to place a bid.
All auction proceeds go to support the legal fund to defend against the frivolous lawsuit filed against us by Streetbeasts.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 01-07-2003, 08:59 PM
ekcaminoron ekcaminoron is offline
New Member
Post fr. disc swap to 65 ekcamino.
whats the best, easiest parts car to use for d/b swap to 65 elkie??? every part from bone yard. p/b booster needed too.
yhanks for all info. greatly apprecieated.
ron
Old 01-09-2003, 06:42 PM
ssaza's Avatar
ssaza ssaza is offline
Post re: fr. disc swap to 65 ekcamino.
use 69-72 chevelle,cutlass,442,gs,skylark,gto,lemans,malibu, monte carlo disc brakes,I have put many sets of disc brakes on my different chevelles.all will bolt on,use the dual master cylinder and power unit,the spindles will bolt on.the later power unit will bolt on the firewall.make sure you get all the brake lines from the master cylinder to the distrubition/proportioning and the front brake lines,plus the valve itself.on the early chevelles,64-66 you will need to split the system,this is why you will need the later model valve and front brake lines.hardest thing to do is to double flare the line to the rear brakes,the fitting are different to the rear,so save the newer fittings,you will need them.This change over is a piece of cake.Good Luck.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
