Hotrodders Bulletin Board
#1
I have a 1954 Ford F-100 That someone has put a Mustang II Front end on, but they didn't put the power steering on it. It has the rack and pinion steering already put on. I was just needing to know what do i have to do to add power steering to what i have already, Thanks for any help you give
#2
You will need
1) power rack and pinion 2) Power steering pump 3) steering pump bracket 4) pulley.. maybe 2 pullies, one for the pump and one a double groove for the crank pulley 5) belt 6) pump to rack hoses 7) depends on the pump you use, if you use a GM pump you'll have to put in a power steering value, to get the pressure down |
#3
Also, depending on the manufacturer of your cross member, you may have to notch the cross member to receive the fatter input shaft.
Trees |
#5
You will want to use a bird rack not a pinto.(slower) Get the valve out of plymouth horizin pump. Its a gm pump but has a diff pressure setting for the rack on those little cars. The adjustable valves dont work. They dont turn the pressure down just slow the transition. I agree stick with the manual if it drives good. Have some pretty big cars with amnual racks. If you go power you will also want to put a bunch of caster in it also...forget the stock specs..car will be real touchy on the highway. They need upwards of 5-7 degrees to make em drive good. less with manaul cause it will be a bear to park with a lot of caster.
