Your choice of IFS kit. Free speech auction: win your choice of Mustang II IFS kit, donated by Progressive Automotive.
Retail value: $1,159.00
Current high bid: $100.00
Click here for details, or to place a bid.
All auction proceeds go to support the legal fund to defend against the frivolous lawsuit filed against us by Streetbeasts.
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 07-19-2003, 12:19 PM
dragn azz dragn azz is offline
69 chevy truck front end change
i have a 69 chevy truck and im changing the front end to disc brake. i heard that you can take the front end of a 78 fire bird, cut the frame on the truck and then put the other front end on the truck. i am making a custom sport truck so performance is a must. is it possible??
Old 07-19-2003, 12:45 PM
TooMany2count's Avatar
TooMany2count TooMany2count is offline
A Half Crippled Old SOB....
 TooMany2count's barnstar
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
re: 69 chevy truck front end change
if I'm not mistaken just about any later model Chevy Truck into the 80's will have the disc brake set up you need. Just get the complete spindle assembly, master cylinder &proportioning valve & you should be good to go. DONT cut the frame cause there's no need to do this just to get disc brakes & as for it being a performance the stock suspension can & will handle anything you can throw at it..BUT you acn by dropped spindles, dropped springs & others if you want it on the ground.....joe
Old 07-19-2003, 01:41 PM
jimfulco jimfulco is offline
71-72 Chevy trucks are good donors. I have a 69 that's getting the whole setup off a junk 71. 73-87 will work if you can find one of them, although there's a little more to it, and the later models in this group use thinner rotors. The board at www.67-72chevytrucks.com has had several fairly recent posts on it, although their search function is dead for the time being. Check it out.
Old 07-21-2003, 10:21 AM
Tony@AirRideTech Tony@AirRideTech is offline
They are correct........... I wouldnt go and cut the crossmember off just to weld on another for disc brakes........ You would not be gaining anything. I would take a set of spindles off of a 73, change the balljoints out in your current control arms along with the tie rod end to accept the new spindle and your set........ other than a power booster, and vavle..........
Old 07-23-2003, 01:16 AM
dharroald's Avatar
dharroald dharroald is offline
Tenacious D Rocks!!!
my '67 has a front end from a '78 pickup. it was installed when i got it so i don't know all that went on to put it in. David
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
