Your choice of IFS kit. Free speech auction: win your choice of Mustang II IFS kit, donated by Progressive Automotive.
Retail value: $1,159.00
Current high bid: $100.00
Click here for details, or to place a bid.
All auction proceeds go to support the legal fund to defend against the frivolous lawsuit filed against us by Streetbeasts.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 12-08-2003, 02:41 PM
shockers69 shockers69 is offline
paint thinner or mineral sprits for parts washer?
I just bought me a cheap 20 gal. parts washer and i need probally about 15 gals. of cleaner i have decided to use a solvent based since the washer will be located where it could freeze i can buy paint thinner for half price of mineral sprits.Other than the less odor with mineral sprits will the thinner do just as well?
Old 12-08-2003, 03:06 PM
machine shop tom's Avatar
machine shop tom machine shop tom is offline
ASE-Certified Master Machinist
re: paint thinner or mineral sprits for parts washer?
Paint thinner is much more flammable that M/S. Also, the thinner will evaporate much quicker than the M/S. Paint thinner may also attack any rubber gloves that you should be wearing when using the parts washer.
Ya cain't fix stoopid, but ya kin TAX it!
Old 12-08-2003, 03:34 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Balanced with heavy metal
Varsol is the accepted standard and safe enough to use in-frequently, always wear your gloves and eye protection.
Has anyone used those citrus based solutions in a parts washer? How well does it work?
Old 12-08-2003, 03:57 PM
astroracer astroracer is offline
STUPID is as STUPID does...
 astroracer's barnstar
PLEASE! Do not use paint thinners or Mineral Spirits in your parts washers! MUCH to flammable! Use the washer recommended cleaning fluid ONLY!
I've used Varsol and a friend of mine is using one of the citrus based cleaners. I really see no difference in performance from one to the other. And will probably try one the next time I need cleaning solution.
Mark
Old 12-08-2003, 04:11 PM
TurboS10's Avatar
TurboS10 TurboS10 is offline
DIY Everything
Just wanted to ditto above. You are asking for a catastropy using either as washer fluid.
Chris
Old 12-08-2003, 05:45 PM
crazy larry's Avatar
crazy larry crazy larry is offline
mineral spirits was the recommended solvent for my cleaner. damn ebay crap. its what i use, we tested it for flammability, and were unsuccessful..... that was last august....
Old 12-08-2003, 06:40 PM
badknuckles's Avatar
badknuckles badknuckles is offline
you talkin to me?
works fine as parts washer i dont know what you would do with your parts washer that it would catch on fire i genarally clean parts
Old 12-08-2003, 08:13 PM
BstMech's Avatar
BstMech BstMech is offline
NYOFP4RJ3CHRIS
When I bought my parts washer I went to Lowe's and bought mineral spirits. It cost ten bucks for five gallons and I got by with ten gallons in a twenty gallon washer. That sure beat spending thirty dollars for five gallons of the recommended solvent.
I've been using it like that for three years and NO problems with flammability or evaporation. Granted, it's evaporated a little and it's about time to add another five gallons (only about a gallon evaporated, but the pump is starting to draw air). It also cleans really well and I can only smell it when the lid is open on the parts washer.
On a side note, if I had put a full twenty gallons of the recommended solvent in there, I would have had more money in solvent than I had in the washer itself.
Old 12-08-2003, 08:48 PM
NAIRB's Avatar
NAIRB NAIRB is offline
7-11 EMPLOYEE
DOESN'T BELONG IN THE ENGINE SECTION
This is a legitimate post, and interesting, but it's in the wrong area of the board. We need to pay attention to where we post. If it's electrical, there is a place for that and a general area for other non-specific topics.
Old 12-08-2003, 08:53 PM
drlindz's Avatar
drlindz drlindz is offline
BAM!-Let's kick it up a notch!
I have had good success with a product called "Citra-Clean".
It takes a little longer to do its job, but it is bio-degradable and smells nice.
Old 12-08-2003, 09:07 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
I like the sound of that, just clean yourself up in the parts washer and splash a little on yourself and you'll be ready to hit the bar on friday night after work.
Old 12-08-2003, 10:20 PM
Sandflea427SS's Avatar
Sandflea427SS Sandflea427SS is offline
Anything with a throttle
Kerosene
Old 12-09-2003, 07:46 AM
MI2600's Avatar
MI2600 MI2600 is offline
Member# 3287
Interesting. I've always used kerosene to clean parts, but w/o the parts washer. I've got a new parts washer in the basement, unused, because I don't have enough floor space left in the garage. Would there be a problem in using kerosene?
Old 12-09-2003, 08:26 AM
RJL's Avatar
RJL RJL is offline
mineral spirits, kerosene, and paint thinner are NOT FLAMMABLE. They are combustibles. You can drop a lit match into a bucket of kero and it will put the match out. But soak a rag in it and put a lit match to it and you will get a nice fire. Now lacquer thinner, gasoline etc is flammable meaning they don't need a carrier(wood,cloth,paper) to ignite. The vapor that these liquids puts off is what burns which is what makes them more dangerous. I would not use mineral spirits as a cleaning solvent in a parts washer. It is not to healthy to breath and you must be careful to properly store your dry off rags. The new citrus cleaners are biodegradable, work well,and are safer.
*bonus*...When you are done you smell like an orchard nor a refinery
Old 12-09-2003, 10:56 AM
wydopnthrtl's Avatar
wydopnthrtl wydopnthrtl is offline
Where do you purchase these citris cleaners and will it freeze?
Rich
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
