Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-08-2002, 02:43 PM
fred56 fred56 is offline
Post Bent rods
I have a 283 sbc that had anti freeze in one cylinder. Without resorting to taking the connecting rods to a machine shop to check to see if their bent, is there an easy and accurate way I can check them myself? Without taking the pistons off? How do I get the wrist pins out? Heat the pistons till they expand and them take the pin out?
Thanks for your help. You guys have been great
Old 11-08-2002, 02:49 PM
slider in wa's Avatar
slider in wa slider in wa is offline
Slider in Wa.
Post re: Bent rods
My opinion is no!!!! If i thought i had the slightest idea i had a bent rod i would have them checked out. I could never knowingly use them and feel safe. I don`t think it would cost that much to have them checked. It is a good time to have the big and little ends checked too!!!
Slider in Wa.
Old 11-08-2002, 02:58 PM
Super Streeter Super Streeter is offline
Post re: Bent rods
Is the engine still together?A pretty good way would be to turn the assembled shortblock over by hand and check the deck height on each piston.If one shows to be lower then the rest by more then a few thousandths,I would look into it.From one end of the block to the other you may find the deck height change,but it should change with each piston,not with one piston higher then the rest.For this test,I recommend checking the height at the center of the piston to minimize variations caused by piston rock.When you are done,bring each piston to TDC and rock it in it's bore from the lifter valley side to the outer side,and see if all the pistons rock about the same amount.If you have one that rocks more then the rest you could have a broken piston skirt.On an unassembled engine you need to had the ods measured,and this is best done at a machine shop.Good luck.
Old 11-08-2002, 03:00 PM
4 Jaw Chuck's Avatar
4 Jaw Chuck 4 Jaw Chuck is offline
Balanced with heavy metal
Post re: Bent rods
To remove the pin you just press them out, usually the pistons are scrap after so don't attempt to reuse them. As for checking for a bent rod there is not any shortcuts that I know of unless you have access to some common machine shop tools like a cylindrical square or at least a surface plate and a dial indicator. There are many ways to check them so how you do it is up to you and the tools you have.
What kind of precision tools do you have? Do you have at least a micrometer, piece of glass, and a dial indicator? You could use these tools to find a bent rod.
You could also use a feeler gauge down the bore once you have the rings removed and have the rod assy temporarily installed, it's not perfect but it will give you an idea.
[ November 08, 2002: Message edited by: 4 Jaw Chuck ]</p>
Old 11-08-2002, 03:11 PM
F-1Rodder's Avatar
F-1Rodder F-1Rodder is offline
Post re: Bent rods
The real issue is whether you hydro locked the engine or not. If it was not started or if there was not enough liquid in the cylinder to cause a hydro lock, then the rods could not bend. Most starter motors will not bend a rod. Bent rods from hydrolocking are usually the result of running them into water (boats sinking) etc.
Old 11-09-2002, 03:01 AM
woodz428's Avatar
woodz428 woodz428 is online now
Post re: Bent rods
I agree with super streeter, if the engine is together a deck height check woukd give pretty conclusive results. I have seen many bent rods that were bent from hydraulicing with the starter motor and the common expression was "I cranked it over and heard an eeeeeh sound", I even keep ome around the shop to illustrate. The gear ratio of the starter/flywheel and how much liquid has entered the cylinder (there by putting the rod in a low enough spot) when it tries to crank is what does it
Old 11-09-2002, 07:59 AM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
Post re: Bent rods
If you're familiar with Ford at all you know they have one of the worst head gasket problems of all time with their 3.8 V6 engine. The shop gets a regular chuckle everytime we see a Taurus or Windstar pull in with that familiar white cloud following behind, not to mention that smell. We rip the top ends of these puppies apart all the time and if we don't see any variences in piston height and she turns over smooth by hand she's good to go. If you're concerned since it's your own engine and have the time a teardown couldn't hurt anything, but at a high volume Ford dealership with regular head gasket failures all we ever did was exactly what I already stated.
Old 11-09-2002, 03:48 PM
Post re: Bent rods
Thanks guys for all the ideas. I checked the deck height before I disassembled the engine and they all seemed to be within a couple thousanths of each other. The reason I think the rods might be bent is that with the rods and pistons out the crank turns freely but with them installed I had a hard time turning the engine over by hand. I think I will go with Slider in that it only costs $125 to have the rods checked. I have to have one cylinder sleeved anyway.
Thanks again.
Old 11-09-2002, 04:27 PM
tm454 tm454 is offline
Tazz
Cool re: Bent rods
Change the piston rings while you are at it. You said you could turn the engine over by hand? I have to use a special crank hub tool with a power bar on it to turn my engines over, sounds like this one is to loose. Rebuild it now while you are at it.
Old 11-09-2002, 04:52 PM
Post re: Bent rods
tm454, when you're turning over an engine to check for a bent push rod you're doing it with the heads off. If you need a breaker bar to turn over a crank without any heads bolted on you've got trouble.
[ November 09, 2002: Message edited by: dmorris1200 ]</p>
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
