Hotrodders Bulletin Board
#1
I want to install an underdash ignition kill switch in my 67 nova...can you help me?The ignition has 4 wires coming out....1 red,1 pink,1 purple with a white stripe,1 brown with a white stripe and 2 smaller wires.I was wondering if I could cut one of these wire and splice in a toggle kill switch?Any help would be greatly appreciated!
PS if I can do this what guage wire shoud I use?thanks bm |
#2
Kill Switch
[color=yellow][size=2]Doc Here
![]() The wire you want is brown. (See Attachment, Schematic for your Car) Th Gauge wire will be exactly the same as provided with the stock harness gauge or better. Be advised, this switch must always be in the "ON" position for normal operation. If it accidentally get knocked off, you may end up looking for problems you don't have. I always recommend, From past experience, If your not using the switch as anti~theft protection, use a lighted switch, so you will know it's on and operating, Or better yet, get a double throw, single pole, switch and on the "Off" side of the terminals hook a Buzzer different sounding from the car's stock buzzers so you will know when the kill switch is off, before you go looking for a bad Ignition, or dead fuel pump... Or at least a 12 volt red led mounted on the dash... Hope it helps Doc [/color][/size]
Aftermarket Solutions Electronic & Electrical Innovations |
#4
re: I want to install an underdash ignition kill switch in my 67 nova...can you help?
i was wanting to do the same thing. i put an aftermarket Crane cams X-RI ignition conversion on my 1974 gto. what wire would i use?
#5
wire
[color=yellow][size=3]Doc here
![]() You want the wire that comes off the run side of the ignition switch. Or the wire that supplies 12 volts to the coil. If it's like the Chevy schematic above, it should be brown. Hope it helps! Doc [/size][/color]
#6
If you are using it as a theft deterrent, I figure that anyone that want's it bad enough is going to get it but might as well make them work for it
#7
KEWL!!
[size=3]Doc here
That's an innovative idea...never heard of it before but sounds like a neat trick! Hopefully the Lighter never popped out on ya going down the road...Murphy is my A Driver... ![]() Doc [/size]
#8
I did the same thing with the cigarette lighter except I put a push-on push-off switch from radio shack at the bottom and just use my finger to activate. It's connected to the Park/Neutral ignition lockout on the transmission so in the off position it thinks its in gear and won't start.
#9
Now wait a minute, I think I missed something... How did you keep the lighter from heating up and popping out? That's a pretty sweet idea... |
#10
when I had a car with an electric fuel pump I would just pull the fuse to the pump.
#11
I bought a battery disconnect switch that is installed between the negative battery cable and the post.---The switch has a nobe on it that one can remove which makes it impossible for any-one to start or take the car....Good luck...
I bought a battery disconnect switch that is installed between the negative battery cable and the post.---The switch has a nobe on it that one can remove which makes it impossible for any-one to start or take the car....Good luck... Last edited by lori-due : 09-10-2004 at 09:01 PM. |
#12
when I put a kill switch on my HEI setup, I ran a nice fat power wire to a high-amp headlight relay that you can get at auto zone, and switched that on and off. That way I bypassed all of the old 1964 "points" wiring (and the resistor wire) and didn't have to run my power wire in and out of the passenger compartment.
#13
Gemini86,
Take out the heater coil and solder in a couple of pennys so that they make the contact when the lighter is pushed in. This becomes a grounding switch so you can use it to close a relay or use it to ground out the ignition when it is pushed in. Lance |
#14
anti steal...
[size=3] Doc here
Back in the days.... Before HEI........ The best anti theft system....... Was cheap and easy............ Pull the coil wire and take the rotor with you! Doc [/size]
#15
Yes I remember those days, as I would just pull the coil wire also. Then someone stole the car and when I found it ,it had one spark plug removed and shoved into the coil and distributor, and it ran on seven cylinders until it ran out of gas !!!
