Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 01-11-2003, 06:28 PM
echauer echauer is offline
New Member
Post carb mix problem
my stock 2.8 has a rochester verajet with all the emission hook-ups. I've eliminated the emission system from the engine and am having trouble with the fuel mix as the verajet has no fuel or air adjustments. Does anyone know of a way to modify this carb to work without the emission system intact?
Old 01-11-2003, 06:33 PM
toymobile toymobile is offline
Post re: carb mix problem
carb has a mixture screw but its sealed. remove carb knock out plug.
Old 01-11-2003, 07:07 PM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
Idle mixture screws only account for your idle quality. If the carb has a mixture control solenoid and you disconnected the computer controls adjusting the idle mixture won't do much. If it doesn't have a mixture control solenoid you'll be ok.
Old 01-11-2003, 08:01 PM
Canzus's Avatar
Canzus Canzus is offline
What I've done in the distant past, is replace
the Vari-Jet with either a Webber 32/36DGAV,
or the Holley/Motorcraft 5200, these are great
little progressive 2BBL carbs, eminantly tunable,
and came, oddly enough, on early 2.8L Mercury
Capris, and Ford Mustang2s so the match was about
perfect right out of the box...
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
