Your choice of IFS kit. Free speech auction: win your choice of Mustang II IFS kit, donated by Progressive Automotive.
Retail value: $1,159.00
Current high bid: $100.00
Click here for details, or to place a bid.
All auction proceeds go to support the legal fund to defend against the frivolous lawsuit filed against us by Streetbeasts.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 02-18-2005, 02:30 PM
Olds 69 Olds 69 is offline
How metering rods work in Rochester Dualjet ?
Me and my friend took apart 79 2mv dualjet on 305 chevy and were wondering what is a function of 2 springloaded metering rods. He was suggesting we should put rods lower into jets (openings on the bottom ) for better economy . I have no clue but it sounds good. Before he shortens that little spring, is he correct ?
Thanks
Old 02-18-2005, 02:56 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Is There Anybody Out There?
re: How metering rods work in Rochester Dualjet ?
To do so will make it run leaner, which is not a wise thing to do, the metering rods control the amount of fuel the engine will get, the further they are in the jets the leaner it gets, and the longer they stay lower will result in a too lean cruise condition that will make the car surge. Too lean can cause overheating as well as other problems, the carb was calibrated from the factory for max efficientcy, I`d leave it that way.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "How metering rods work in Rochester Dualjet ?"
Scotts Hot Rods, Work - Good or Bad? dwyerk Hotrodders' Lounge 13 10-14-2007 12:37 AM
"a little over" turns into $4500 over for paint job bullheimer Body - Exterior 128 02-06-2006 08:57 AM
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 08:42 PM
new rods or old rods? Blob Engine 12 02-03-2004 04:35 PM
Q-Jet Metering Rod Idea Silver_Camaro Engine 6 09-16-2003 01:48 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
