Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 02-11-2003, 03:59 AM
Slyfox Slyfox is offline
New Member
Post HEI Advance curve
HEI Advance curve:
I am hoping someone can help me out, after reading a article on changing the advance curve on a HEI distributor (http://www.boyleworks.com/ta400/psp/distcurve.html) I need some part numbers: The GM part number for a #398 center plate and a #139 weight also the bushing for the weights. The local GM dealer has no listing on these parts separately (only the complete shaft assembly). Can anyone out there help?
Mechanical advance begins at 900 rpm and increases as follows:
rpm Degrees rpm Degrees rpm Degrees
1000 6 2000 13 3000 17
1200 9 2200 14 3200 18
1400 11 2400 15 3400 18
1600 12 2600 16 3500 19
1800 12 2800 16
Figure 1: Results using a #398 center plate, #139 weights, and moderate springs.
Old 02-11-2003, 05:14 AM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
Arrow re: HEI Advance curve
You need Accel Kit Nos.
31041 Advance Curve Kit
31035 Adjustable Vacuum Advance
JEG'S or Summit
Old 02-11-2003, 07:30 AM
New Member
Post re: HEI Advance curve
Thanks Kultulz, that is what I am currently using (not got the vacuum advance yet) but I am not completely satisfied with this kit and would prefer GM stuff if I can get the same or better results also to quote the above mention article: “most aftermarket curve kits of weight and springs, and a center plate are not very accurate and may provide a poorer curve than what exists. (The medium and heavy springs in these kits can be used with stock weights.) .
I know this is one person’s opinion but look at and feel the GM stuff and the way it fits compared to the aftermarket stuff. But thanks for the in put and I do plan on getting the vacuum advance unit.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
