Your choice of IFS kit. Free speech auction: win your choice of Mustang II IFS kit, donated by Progressive Automotive.
Retail value: $1,159.00
Current high bid: $100.00
Click here for details, or to place a bid.
All auction proceeds go to support the legal fund to defend against the frivolous lawsuit filed against us by Streetbeasts.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 01-18-2002, 05:19 PM
jaw2 jaw2 is offline
Post shifter cable
how far in front of the shifter should you drill the hole in the floor for the cable,its a 400 tubo with a hurst quarter stick.thanks jeff
Old 01-19-2002, 01:26 PM
lakeroadster's Avatar
lakeroadster lakeroadster is offline
Hot Rods are Built, not Bought
Post re: shifter cable
I installed a Hurst V-Matic in my '31 Ford. There was a rubber grommet that the cable goes through to protect it from the hole you cut in the floor. As I recall the bushing is just past the shifter mounting bracket. If all else fails, assemble the entire deal out on your workbench, then you can see measure where the hole should be drilled and transfer it to the floorpan.
The key is to make sure the cable isn't in a bind.
You might try e-mailing Hurst. You will find them at Mrgasket.com
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2009. All Rights Reserved.
