What is the best way to remove a 1978 Trans Am sub frame without removing the engine or trans.
I'm getting there I am currently in the process of putting epoxy primer on all my front end sheet metal.malc said:What´s the story so far, have we got that subframe out ?
Thanks for the tip. I'll check the trans cooler lines. The engine has been out. Someone put a sb Chevy 350 in it but it still has the BOP Turbo 350 Transmission.So you're pulling the engine/tranny now? Thats good, will make it much easier. Remeber the trans cooler lines are bolted to the oil pan on the passengers side. They will bend if you dont disconnect them from the engine. This is assuming you have an auto and the engine hasn't been out before.
This was done w/an adapter plate, right? Be sure to keep track of the special spacer washers that are between the torque converter and flex plate if you remove the transmission.Someone put a sb Chevy 350 in it but it still has the BOP Turbo 350 Transmission.
Of course. I don't think it can be done without an adaptor of some sort.This was done w/an adapter plate, right? Be sure to keep track of the special spacer washers that are between the torque converter and flex plate if you remove the transmission.![]()
The F-cars generally won't sallow the engine to be pulled w/the headers attached- as you found out. You don't need to try to remove them, though. Just remove the bolts and slide them away from the engine just enough so they don't catch on anything.Boy, what fun I had today.
I removed part of the exhaust(headers to muffler joint pipe) to allow ease when working on the floor rust. Whoever installed it used one of those dumb clamps that crush the pipe. I tried to remove it without cutting but got fustrated and just chopped it off. I'll weld it back later.
I still had the slip yoke in the rear of the tranny. I tried to put a milk jug under it to catch the tranny fluid when I slid the shaft out the rear. The darn uv joint on the shaft hit the funnel spilling tranny fluid all over me and the floor. When I finally got the funnel back under it, turns out the damn jug was leaking.
When all hell was done I was finally ready to pull out the engine/trans. I got the mounts off the frame and tried to slide the engine/tran out. Turns out the header is getting caught on the bottom of the firewall where it meets the floor.
I am done for today. I guess tommorow I have to yank out the headers.
Wish me luck!!!!!
