Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 01 Silverado pulls left.
Old 11-07-2018, 04:59 PM
LATECH's Avatar
LATECH LATECH is offline
Last journal entry: GTO Reproduction Hood
Originally Posted by AFX View Post
It still pulls left and that caliper still drags.
Could this be the brain that controls the ABS ?
Thanks for any responses
Dragging caliper is a hydraulic problem
Most the only thing left will be the electro hydraulic ABS unit.
The valving inside allows pressure to be dumped, blocked or modulated application on each line independently . Could be a valve is stuck inside keeping the pressure blocked .
Loosen the bleeder see if the caliper releases. That will be a pretty good indicator.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
AFX (11-07-2018)
