01 Silverado pulls left. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2018, 06:18 AM
AFX's Avatar
AFX AFX is offline
I have been up and down for over a year trying to get this figured out.
01 silverado, crew cab, 2wd 200,000 plus miles.
Started pulling left over a year ago, thought it was a loose wheel bearing.
All these components have been replaced on both sides of the truck.
Long story/short... These parts are upper level " no auto zone. "
New Upper control arms, Calipers-left twice, Rotors, GM pads, Left brake line, Ball joints, Bushings, Steering rack, Tie rod ends, Front tires, Wheel bearings.
It still pulls left and that caliper still drags.
Could this be the brain that controls the ABS ?
Thanks for any responses
Old 11-07-2018, 02:24 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Did you check Car-Fax for accidents that might have involved the frame?
Old 11-07-2018, 03:49 PM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
Did you change the flex hose too?
Could be there is an obstruction in it, so that caliper can't release
Is ABS light on?
Old 11-07-2018, 04:59 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Dragging caliper is a hydraulic problem
Most the only thing left will be the electro hydraulic ABS unit.
The valving inside allows pressure to be dumped, blocked or modulated application on each line independently . Could be a valve is stuck inside keeping the pressure blocked .
Loosen the bleeder see if the caliper releases. That will be a pretty good indicator.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
AFX (11-07-2018)
Old 11-07-2018, 08:56 PM
AFX's Avatar
AFX AFX is offline
I have had the truck for almost 10 years and it hadn't done it till a little over a year ago.
Old 11-07-2018, 08:59 PM
AFX's Avatar
AFX AFX is offline
That sounds like a good check. I hear it's not a cheap module. Thanks
Old 11-07-2018, 09:01 PM
AFX's Avatar
AFX AFX is offline
[QUOTE=poncho62;4633507]Did you change the flex hose too?
Is ABS light on?[/QUOTE
Yes the brake line/ hose has been replaced.
The ABS light comes and goes for quite a few years now. It seems to turn off more in the wet.
I hear that is a common problem and it turns up to be a ground on the ABS module. I haven't looked at that yet.
Old 11-08-2018, 10:44 AM
These years have bad lines. They rust easily outside and inside. Remove your flex line and flush it pouring it into something clear while adding new fluid. Good chance you have a slug of rust debries
The Following User Says Thank You to cerial For This Useful Post:
AFX (11-09-2018)
Old 11-08-2018, 04:20 PM
LATECH's Avatar
Not that bad actually. Salvage yard units are fine. Just be sure to perform the automated bleed sequence after install.
The electronic parts can be re used from your unit,or you can leave it alone and use the whole yard unit.
Probably best to bolt on a complete unit.If the electronic part failed as well, that can be purchased remanned, or like I said , swap it out.
There are a bunch of little seal between the valve unit and the control unit that will need some silicone/dielectric grease applied to.It keeps them sealed from dirt/water .
Just sayin
The Following 2 Users Say Thank You to LATECH For This Useful Post:
AFX (11-09-2018), cerial (11-08-2018)
Old 11-08-2018, 04:51 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I blame the hard line myself. Seen it happen a bunch of times.
Another clue would be the pads wearing funny. If one is thinner than the other the caliper could be sticking and if both are worn the same but not parallel to the caliper could be bound up on the spindle.
Old 11-10-2018, 05:08 PM
I've a steering box pull to one side constantly, but that was after hitting a curb.
Old 11-11-2018, 08:20 AM
55 Tony's Avatar
I've had my 2000 Express 3500 from new, I'd guess the brakes are the same. It always wore one pad more than the other, way more! Turned out the calipers were sticking, but only when they got hot. It's tough to explain where the bind was but I took a belt sander to both sides until they had more clearance. (precision work) One side I had to go back and do it more. They wear even ever since. Also recently changed a leaking rear wheel cylinder and holy crap the fluid was nasty! I bled all 4 corners until they ran clean.
Pulls to left - Alignment or Brakes jayd_2 Suspension - Brakes - Steering 14 11-08-2014 05:33 AM
Truck pulls to left with offset wheels only tommytempest Suspension - Brakes - Steering 4 12-30-2004 05:30 AM
76 vette pulls left, then straight, then right! corvette jim Suspension - Brakes - Steering 12 10-17-2004 09:20 PM
57 Chevy pulls to left when braking belairman_57 Suspension - Brakes - Steering 7 10-14-2004 11:57 AM
car pulls to the left and sometimes to the right during braking? 72Nova Suspension - Brakes - Steering 7 09-30-2002 08:02 AM
