02 liberty - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2017, 05:35 AM
02 liberty
hi there, i have an 02 liberty with the 3.7 and replaced both head gaskets and cam sensor and the engine turns over slow it seems and wont fire. Please I need some advice
Old 04-15-2017, 06:28 AM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Did you keep the cam caps in order?
Fact is stranger than Fiction
Old 04-16-2017, 07:20 PM
02 liberty
Yes but i have found that the guide pin on right side cam to sprocket gear was rounded on one sied and spun independent from cam
Old 04-16-2017, 08:01 PM
LATECH's Avatar
Then you may/probably have some bent valves
Chances are the timing (Cam/crank) was not correct. OOPS
Old 04-16-2017, 08:03 PM
LATECH's Avatar
Pull the cams so the valves are closed and do a leakdown test. Reason to pull both,and remove timing chains is because he crankshaft will rotate when you charge the cylinder.
If you are careful enough not to apply to much pressure (leakdown tester) you can just pull cam on one side as low pressure wont turn the crank over.A cylinder with bent valves will leak pressure so the crank wont spin, but when you get to a good set of valves, it might , unless you are careful and use the proper tool.(leakdown gauge/tester)
Old 04-16-2017, 08:13 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Did you disconnect an electrical ground strap that you forgot to re-connect?
Old 04-16-2017, 08:24 PM
LATECH's Avatar
That too..........
05 jeep liberty problems Garris1 Engine 3 10-25-2012 05:48 AM
2001 jeep liberty misfires jerryvarnell Engine 7 10-15-2011 08:10 PM
liberty-lenco transmissons timtimgivens Transmission - Rearend 1 05-31-2007 12:13 AM
introduction liberty speed liberty speed Introduce Yourself 2 04-28-2007 01:23 AM
jeep liberty 53belair Transmission - Rearend 1 03-10-2007 10:29 PM
