Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1.3 / 1.4 tips for SPI clear
Old 02-25-2014, 06:01 AM
shine's Avatar
shine shine is offline
SPI Thug
Last journal entry: some progress
a lot of cheaper guns end up piling on the clear. the larger the tip the thicker the coat . that was a big issue with older siphon guns . they just would not break it up unless you cranked up the air and you ended up hosing it on . with clear i prefer multiple thin coats instead of heavy coats.
