1/8 NPT Banjo bolt? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-14-2020, 05:39 AM
The Red 180 dec fitting is connected to the caliper as per hose #9.
  #17 (permalink)
Old 02-14-2020, 07:41 AM
S10xGN's Avatar
Gotta love a turbo!
Originally Posted by staleg View Post
...Another possibility is to switch around the brake hose and the bleeder.
I prefer not as you have to loosen the caliper and turn it upside down when bleeding the brakes.
Can you swap calipers side to side? That would keep your bleeders on top...
Russ
  #18 (permalink)
Old 02-17-2020, 05:22 AM
staleg's Avatar
Last journal entry: Hand brake
The calipers are not left/right spesific.
Bleeder and inlet ports are both 1/8 NTP
  #19 (permalink)
Old 02-17-2020, 05:34 AM
staleg's Avatar
Originally Posted by 2old2fast View Post
You could spot face the caliper and drill and tap the existing 1/8 npt hole for 7/16-20 threads making it possible to use standard banjo fittings ....
That could been a neat solution, yes.
Unfortunately there aren't any 7/16 banjos with side bend.
But drilling out the 1/8 NTP inlet port to something else, might be a good idea.
  #20 (permalink)
Old 02-17-2020, 06:33 AM
What's a " side bend" ?
  #21 (permalink)
Old 02-17-2020, 08:35 AM
It appears that you have a full aftermarket suspension , does it incorporate steering stops that limit the turning radius ? Could be that limiting the turn could provide the clearance you need , if its within reason ....
BTW Russell performance has all sorts of different banjo fittings ...
  #22 (permalink)
Old 02-17-2020, 09:57 AM
staleg's Avatar
90 degree side bend banjo:
https://www.ebay.com/itm/Goodridge-B...8AAOSwBOlacdVP
90 degree "not side bend" banjo:
https://www.ebay.com/itm/NEW-Goodrid...YAAOSwDhdc1x~L
  #23 (permalink)
Old 02-17-2020, 10:16 AM
I see ! OK , how about drilling our the caliper and tap to 1/2"-20 , then use a reducer bushing to get to 3/8or 10mm. With the sealers that are available today , ID think that would be doable , I've seen those work on heavy equipment fittings where the hydraulic pressures are way above a brake system ....
Course I've welded hydraulic supply lines too .....��
The Following User Says Thank You to 2old2fast For This Useful Post:
staleg (03-03-2020)
