1932-34 model "b" 4 cyl with with riley 2port cyl head and intake 2 stromberg 97 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2014, 05:09 AM
I have a 1933 American Austin Coupe with a 32-34 model b 4 cyl cylinder head is 2 port Riley (yapp) intake 2 stromberg 97 ...crank counter balanced and drill for oil pressure cam 280 degree . 340 lift light flywheel and 9" ford clutch dist. Stock model a 12v altenator audisy 12vbat trans 32 ford 3speed rear end model a ford 3.73 coil cover springs brakes 48 ford (f1 front) front end-drilled 36 ford axel spring behind no shocks radiator 29 ford model a spark plugs ngk b-4es or equive..... ok so I am having troublegetting gas to the motor..... when I push the accelerator it dies ...the fuel pump is down in front of the car and the gas tank is behind the seat does it need to be back by the tank?...... any suggestions?
Old 02-15-2014, 06:48 AM
32-34, ford v4, riley 2port heads
cyl head help, motors almost done blight Engine 6 05-29-2010 03:27 AM
"bolt-on" master cyl. for 66 nova.... sc2dave Suspension - Brakes - Steering 0 05-25-2008 12:36 AM
2000 Sunfire, Fuel pump stopped pumping, changed it, started, & read "misfire cyl. 1" jordan2011 Engine 6 04-28-2008 08:57 PM
Model A Donor For Master Cyl. bluestang67 Suspension - Brakes - Steering 3 03-11-2007 12:09 AM
intake bolt patterns for 6 cyl.'s jalopy45 Engine 2 10-24-2002 04:11 PM
