Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1932 window frame/posts on 1927 Ford Roadster
Old 03-05-2018, 09:21 AM
bubbamace's Avatar
bubbamace bubbamace is offline
Originally Posted by 39 master View Post
If you look at the Speedway lo boy windshield post they can be used on your car I think. I made a set for my last '32. Note there is a slot for the glass to go into on the Speedway post. To further seal and support the glass I cut a trough across the cowl and set the glass down into it also. Very clean and small.
Thanks 39 master. I'll definitely have a look.
Sent from my SM-G900V using Tapatalk
