1938 BMW 327 Cabriolet Door Jamb Fabrication - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2018, 05:55 PM
Hammerform for rear door jamb / B-pillars for 1938 BMW 327. This is a continuation from the other posts regarding the fabrication of these complex parts. The hammerform is made of solid maple covered with 14 gauge steel. The part is being made of .037" sheet metal, the same thickness as the original part. It's cut slightly oversize and registered on the hammerform. A center punch is used to locate the 3 holes that need to be drilled to accommodate the bolts that secure the wood blocks that prevent the metal from shifting. A plastic mallet is used to manipulate the sheet metal down over the edges. A Goose-neck planishing hammer with a rounded end is used for the next stage to move the metal down and into the stepped flanges. A sharper bullnose corking tool is then used to chase the bottom creases of the flanges. I then made a set of edging dies and ran the part though the power hammer to smooth all of the bends.
ID:	418186   Click image for larger version
ID:	418194   Click image for larger version
ID:	418202   Click image for larger version
ID:	418210   Click image for larger version
Old 06-09-2018, 06:21 AM
The finished door jambs.
Old 06-09-2018, 07:22 AM
Amazing work. Did you use a low carbon draw steel?
John
Old 06-09-2018, 02:49 PM
No, just regular 19 gauge (.040") thick sheet metal.
1938 Pontiac touring sedan frame fabrication Hotflint Suspension - Brakes - Steering 9 06-01-2016 12:07 AM
1938 BMW Seat Spring Steel Frame Question dcygan Interior 25 02-22-2015 10:13 AM
Door Jamb Jeff13 Body - Exterior 0 01-22-2013 07:08 PM
Door jamb connectors? ScotY Electrical 7 06-03-2009 06:58 PM
door jamb contacts - 37 ford adcox Electrical 0 02-13-2009 08:50 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
