1941 Chrysler New Yorker Hot Rod - Page 10 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #136 (permalink)
Old 09-29-2019, 06:31 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Hi, Pugsy.
Whats new, anything?
Your pieces look outstanding.
  #137 (permalink)
Old 09-30-2019, 05:03 AM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by idrivejunk View Post
Hi, Pugsy.
Thanks. Yep, welded in. Updates to follow.
The Following User Says Thank You to 123pugsy For This Useful Post:
idrivejunk (09-30-2019)
  #138 (permalink)
Old 10-02-2019, 06:16 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Pics of how I cut thicker metal. I found this nibblin' machine for cheap years ago. No plasma cutter so I just make a template from thin wood that I can cut with snips and smooth into shape on my belt sander. Clamp the thin wood to the sheet and it rides on the nibbler punch and traces it exactly. Well, not exactly, just needs some smoothing on the belt sander. I can cut 1/8" thick sheet with it. Sweet.
This is 14 ga in the pics.
ID:	448487   Click image for larger version
ID:	448489   Click image for larger version
ID:	448491   Click image for larger version
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (10-03-2019), idrivejunk (10-02-2019)
  #139 (permalink)
Old 10-02-2019, 06:20 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Tacked and welded..............
ID:	448495   Click image for larger version
ID:	448497   Click image for larger version
ID:	448499   Click image for larger version
The Following 3 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (10-03-2019), idrivejunk (10-02-2019), NEW INTERIORS (10-06-2019)
  #140 (permalink)
Old 10-02-2019, 06:23 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Same routine a the bottom...........
ID:	448503   Click image for larger version
ID:	448505   Click image for larger version
ID:	448507   Click image for larger version
  #141 (permalink)
Old 10-02-2019, 06:27 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
How to screw up a perfectly (not so) good hood:
Finding the pivot point. (Too far back here)
ID:	448511   Click image for larger version
ID:	448513   Click image for larger version
ID:	448515   Click image for larger version
The Following 4 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (10-03-2019), idrivejunk (10-02-2019), NEW INTERIORS (10-06-2019), Rip VW (10-02-2019)
  #142 (permalink)
Old 10-02-2019, 06:40 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Those of you with a keen idea would have noticed the round corners at the bottom of the hood by now to clear the fenders.
Cowl/hood/fender intersection is a very bad place to be in the hot rod building process and has had me stalled for a while. That and getting a new DD, installing hitches and stuff.....all take time. But mostly getting my head around this intersection....
Gearhead Poppa (10-03-2019), idrivejunk (10-02-2019), NEW INTERIORS (10-06-2019), Rip VW (11-01-2019)
  #143 (permalink)
Old 10-02-2019, 06:46 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
I needed an offset patch with a curve to match the hood. Well, the hood can match the patch later easily enough.
I used my hydraulic knockout punch with inverted punch into an oversized die to press the step. This could be done in a vise using a socket and a short piece of thick walled tube. (I'm pretty sure anyways)
ID:	448521   Click image for larger version
ID:	448523   Click image for larger version
ID:	448525   Click image for larger version
  #144 (permalink)
Old 10-02-2019, 06:50 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Those of you with a keen eye would have noticed the radius did not blend properly in the last pic where it transitioned from cowl to hood corner.
No problem, just a short weld extra.....
ID:	448529   Click image for larger version
ID:	448531   Click image for larger version
ID:	448533   Click image for larger version
The Following 5 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (10-03-2019), idrivejunk (10-02-2019), NEW INTERIORS (10-06-2019), Rip VW (10-02-2019), Too Many Projects (10-02-2019)
  #145 (permalink)
Old 10-03-2019, 05:12 AM
Good stuff Pugsy. It is really good to see you back in the shop.
Now if we can just get some other people moved and settled in....................
John
The Following User Says Thank You to John long For This Useful Post:
123pugsy (10-03-2019)
  #146 (permalink)
Old 10-03-2019, 05:43 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
John
Thanks.
Ya, wild eh? Three of the pack moving at the same time. Two of em building.
  #147 (permalink)
Old 10-03-2019, 07:33 AM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
Won't be any car related work getting done here until next summer. New place has no heat and once I get all my "stuff" moved, no room to work either.
I DID drive the Camaro 50 ft to load on the trailer and bring to the new place last week, the ONE day it didn't rain. Off loaded here, drove it in the shop, onto the lift and pulled the battery.
New pole shed has already been pushed back to the end of October and that's IF IT EVER stops friggen raining NOW... We are 11" over normal for rain for this time of year. If it keeps raining, it may not get built this year...
If it gets cold early, with no snow, the frost will go down fast and deep, with the soil so saturated. I'm on sandy ground here, but the builder doesn't work in cold weather, which I agree with. Too many issues later with expansion of wood that was nailed together in a frozen state.
The Following User Says Thank You to Too Many Projects For This Useful Post:
  #148 (permalink)
Old 10-10-2019, 09:12 PM
Jordan Owens's Avatar
You are a amazing metal worker. This is one I have been working on
The Following User Says Thank You to Jordan Owens For This Useful Post:
123pugsy (11-10-2019)
  #149 (permalink)
Old 10-26-2019, 07:56 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Thanks Jordan. Welcome aboard.
Nice looking project. You should start a build thread. Lot's of us here love to follow along and "hang out" in your garage with you.
  #150 (permalink)
Old 10-26-2019, 08:01 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
I had to do some major banging in at the top of the new patch at the pointy part to get the required offset for the hood to clear. I then needed a wiggly patch to match to weld onto the fender as a new flange piece at the top.
ID:	449059   Click image for larger version
ID:	449061   Click image for larger version
ID:	449063   Click image for larger version
ID:	449065   Click image for larger version
Gearhead Poppa (10-26-2019), idrivejunk (10-26-2019), Rip VW (11-01-2019), Too Many Projects (10-26-2019)
