1941 Chrysler New Yorker Hot Rod - Page 12 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #166 (permalink)
Old 11-30-2019, 05:55 AM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Wiper holes filled next......
ID:	450087   Click image for larger version
ID:	450089   Click image for larger version
ID:	450091   Click image for larger version
ID:	450093   Click image for larger version
The Following 3 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (11-30-2019), idrivejunk (11-30-2019), John long (11-30-2019)
  #167 (permalink)
Old 11-30-2019, 06:47 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
A bit of heat and persuasion took care of the cowl flange.
ID:	450099   Click image for larger version
ID:	450101   Click image for larger version
ID:	450103   Click image for larger version
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
  #168 (permalink)
Old 11-30-2019, 07:01 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Mitch posted some hot rod hinges so I thought I would mock up the design.
ID:	450107   Click image for larger version
ID:	450109   Click image for larger version
ID:	450111   Click image for larger version
  #169 (permalink)
Old 11-30-2019, 07:03 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Closing down.............
ID:	450115   Click image for larger version
ID:	450117   Click image for larger version
ID:	450119   Click image for larger version
  #170 (permalink)
Old 11-30-2019, 07:11 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Wiper transmissions next. Needed to cut a piece of defogger duct out of the way in order to insert them.
I'll finish the welding on the roto so I can get into a comfortable position. Only one shot at welding these properly. Cannot just smooze Bondo all around after.
ID:	450123   Click image for larger version
ID:	450125   Click image for larger version
ID:	450127   Click image for larger version
ID:	450129   Click image for larger version
  #171 (permalink)
Old 11-30-2019, 07:14 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Covers ready to go and preinstalled. Notes marked on the covers so I don't forget later.
ID:	450133   Click image for larger version
  #172 (permalink)
Old 11-30-2019, 07:18 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Mock up of hinge pockets. The strip of metal represents where the fender will be. Looks like some wiggle will need to be added to the hinge arms. Lots of room at the top to attach to the hood.
ID:	450137   Click image for larger version
ID:	450139   Click image for larger version
ID:	450141   Click image for larger version
  #173 (permalink)
Old 11-30-2019, 07:25 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Made a flange for the defogger reducer on the shrinker. Was curious if I could shrink a flat strip to 2" diameter.
Used some s/s rods to make hose keeper onners.
Used a hole saw to add a 2" hole on the driver's side and put a divider in the factory duct. Should get some good airflow from the VA unit.
ID:	450145   Click image for larger version
ID:	450147   Click image for larger version
ID:	450149   Click image for larger version
ID:	450151   Click image for larger version
The Following User Says Thank You to 123pugsy For This Useful Post:
  #174 (permalink)
Old 11-30-2019, 07:43 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Patch at cowl. Forgot to post earlier, D'OH!
ID:	450155   Click image for larger version
ID:	450157   Click image for larger version
ID:	450159   Click image for larger version
ID:	450161   Click image for larger version
  #175 (permalink)
Old 11-30-2019, 08:43 AM
I spent some time catching up with you this morning Pugs. Good stuff. I am really glad to see you are back at it!
John
The Following User Says Thank You to John long For This Useful Post:
123pugsy (11-30-2019)
  #176 (permalink)
Old 12-03-2019, 05:52 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
John
Thanks John. Glad to see you following along and it's good to be back at it. I'm starting to "feel it" again.
  #177 (permalink)
Old 12-03-2019, 05:57 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
The plan is to use a 90 brake set up from Kugel and build a cubby into the firewall to house the hydro boost , brake lines and power steering lines.
I can't stand the idea of having all that juice inside the car and crawling around under the dash for repairs. I dropped the body down, cut off an ear from the bell housing and got 2" more floor and 1" more firewall at the top.
Then, I made a template from steel L angles so I could figure out the cowl extensions at the top.
ID:	450205   Click image for larger version
ID:	450207   Click image for larger version
ID:	450209   Click image for larger version
ID:	450211   Click image for larger version
ID:	450215   Click image for larger version
Gearhead Poppa (12-03-2019), idrivejunk (12-03-2019)
  #178 (permalink)
Old 12-03-2019, 06:01 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Cowl bits. I took a paper pattern, cut the shape and used a hand tipping tool to fold it.
Still too lazy to bring the bead roller home.
ID:	450219   Click image for larger version
ID:	450221   Click image for larger version
ID:	450223   Click image for larger version
ID:	450225   Click image for larger version
  #179 (permalink)
Old 12-03-2019, 06:05 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
I got the Kugel brake pedal yesterday and mocked it up.
The AC unit fits right behind the master so I believe it should work out as planned.
The cubby will be stainless with a drain tube down to the street.
Added bonus. There may be enough room for the PCM as well as the wiper motor in the cubby. Now, how to run the spark plug wires out of there so I can install the 8 coils as well? Hmm......
ID:	450229   Click image for larger version
ID:	450231   Click image for larger version
idrivejunk (12-03-2019), John long (12-04-2019)
  #180 (permalink)
Old 12-07-2019, 11:13 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Back to the hinge pockets before I can install the new cowl bits.
New hood hinge mock up. Made a stronger hinge.
ID:	450263   Click image for larger version
ID:	450265   Click image for larger version
ID:	450267   Click image for larger version
Gearhead Poppa (12-07-2019), idrivejunk (12-07-2019), Too Many Projects (12-07-2019)
