1941 Chrysler New Yorker Hot Rod - Page 14 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #196 (permalink)
Old 12-13-2019, 02:20 PM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Made up the last chunk for the upper cowl, driver's side.
ID:	450415   Click image for larger version
ID:	450417   Click image for larger version
The Following 3 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (12-14-2019), idrivejunk (12-13-2019), Too Many Projects (12-13-2019)
  #197 (permalink)
Old 12-13-2019, 02:22 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Hinge pocket locating pattern. Just flip the tape upside down and apply on the other side.
ID:	450421   Click image for larger version
idrivejunk (12-13-2019), John long (12-13-2019), Too Many Projects (12-13-2019)
  #198 (permalink)
Old 12-14-2019, 09:55 AM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Remarkable skill and precision. Best thread ever! We all have a lot to learn from you. Thank you so much for posting this.
The Following User Says Thank You to idrivejunk For This Useful Post:
123pugsy (12-14-2019)
  #199 (permalink)
Old 12-14-2019, 05:55 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Thanks Matt.
  #200 (permalink)
Old 12-14-2019, 06:03 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
I checked with the laser level, after cutting the hole. Wish I read Matt's post prior to cutting. I would have thought to check it while the pattern was still on the car. Oh well....a little low.
I cut through the hinge pocket reinforcement so I need to add some 11 ga plate in there to stiffen things up.
ID:	450443   Click image for larger version
ID:	450445   Click image for larger version
ID:	450447   Click image for larger version
The Following 4 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (12-15-2019), idrivejunk (12-15-2019), John long (12-14-2019), Too Many Projects (12-15-2019)
  #201 (permalink)
Old 12-17-2019, 05:40 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Almost done the passenger side cowl, top section.
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (12-18-2019), idrivejunk (12-17-2019)
  #202 (permalink)
Old 12-17-2019, 05:55 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
You keep this pace up, you'll be driving it next summer...
The Following User Says Thank You to Too Many Projects For This Useful Post:
123pugsy (12-17-2019)
  #203 (permalink)
Old 12-17-2019, 06:49 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Ha..thanks.
The pace is about to hit a crawl as I work thru a whack of mechanicals. I picked up a Vette (C3) master cylinder that fits the Express van hydroboost so I'll be able to start mocking up the "cubby" after this cowl business.
idrivejunk (12-17-2019), Too Many Projects (12-17-2019)
  #204 (permalink)
Old 12-27-2019, 05:52 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Back to my old ways. Checking after the fact....D'OH!
ID:	450755   Click image for larger version
ID:	450757   Click image for larger version
ID:	450759   Click image for larger version
Gearhead Poppa (12-27-2019), idrivejunk (12-27-2019)
  #205 (permalink)
Old 12-27-2019, 06:12 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Booster adapter. This got it level.
ID:	450769   Click image for larger version
ID:	450771   Click image for larger version
  #206 (permalink)
Old 12-27-2019, 06:18 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Klooongg.....(light bulb).....if I could angle the tube to get it level, why not angle it at the other end to bring it and the master forward giving more space for the AC behind it?
This also got the rod aiming straighter with the booster.
ID:	450775   Click image for larger version
ID:	450777   Click image for larger version
Gearhead Poppa (12-27-2019), idrivejunk (12-27-2019), Too Many Projects (12-30-2019)
  #207 (permalink)
Old 12-27-2019, 01:35 PM
idrivejunk's Avatar
Grand Prix User
Including thought process like that makes the most educational thread. Keep it up!
123pugsy (12-27-2019)
  #208 (permalink)
Old 12-30-2019, 04:10 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Firewall cubby cover started............
ID:	450827   Click image for larger version
ID:	450829   Click image for larger version
ID:	450831   Click image for larger version
ID:	450833   Click image for larger version
Gearhead Poppa (12-30-2019), idrivejunk (12-30-2019), John long (12-30-2019), Too Many Projects (12-30-2019)
  #209 (permalink)
Old 12-30-2019, 06:23 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
These corners are a ton of work to get decent.
One little bit left to fine tune and tack into corner number 5 tomorrow. This will give me enough info to start the firewall panels that go around the cubby door.
I'm guessing a 1/8" gap all around for the weather stripping I ordered from Steele.
https://www.steelerubber.com/peel-n-...dium-p-profile
ID:	450851   Click image for larger version
ID:	450853   Click image for larger version
ID:	450855   Click image for larger version
  #210 (permalink)
Old 12-30-2019, 11:00 PM
Molon Labe's Avatar
Last journal entry: Floors
Pugsy,
Is it the difficulty in getting the length of the chamfered area on the corners to match perfectly with the length of the chamfer on the panel that makes it easier to make the corners in two pieces?
