1941 Chrysler New Yorker Hot Rod - Page 15 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #211 (permalink)
Old 12-31-2019, 07:39 AM
123pugsy's Avatar
Purists Hate Me
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by Molon Labe View Post
Pugsy,
Is it the difficulty in getting the length of the chamfered area on the corners to match perfectly with the length of the chamfer on the panel that makes it easier to make the corners in two pieces?
That and they need to be in two pieces to get them into the shrinker stretcher jaws. Pic below. Same idea.
Shrinking and stretching the angles must be done with the 45 degree corner at about 80 degrees to get the flange between the jaws of the shrinker stretchers. Then, change the flange angle back to 45 degrees to check the radius. If it's wrong, change the bend to about 80 again, try it, etc..etc...until the piece is the correct shape and the bends are back at 45 degrees.
Fitting: when you overlap two pieces to mark the cut line, the size is not correct. Trim, check, grind a smidge, check again, etc.
Tacking them up and keeping everything as dead flush as possible is time consuming as well.
One corner left, so ________ (insert fist pump smiley here).
Name:	IMG_3453 (Medium).jpg
The Following 4 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (12-31-2019), idrivejunk (12-31-2019), John long (12-31-2019), Molon Labe (12-31-2019)
  #212 (permalink)
Old 12-31-2019, 09:25 PM
Lots of work Pugsy. Are you getting back into mood to work in the shop?
John
The Following User Says Thank You to John long For This Useful Post:
123pugsy (01-01-2020)
  #213 (permalink)
Old 01-01-2020, 05:51 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
John
Thanks, actually, yes, back in the groove.
I gotta go bend me up some firewall this morning at work.
All corners tacked and panel measured up. I'll shoot for a 1/8" to 3/16" gap all around for the weather/anti rattle stripping.
The Following 3 Users Say Thank You to 123pugsy For This Useful Post:
idrivejunk (01-01-2020), John long (01-01-2020), NEW INTERIORS (01-03-2020)
  #214 (permalink)
Old 01-01-2020, 10:17 AM
Your just trying to show the rest of us up.
Good job.
John
  #215 (permalink)
Old 01-01-2020, 02:08 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
In my best Groundskeeper Willie (the Simpsons) accent:
Well done lad! That'll do.
Mitch had an interesting idea for that cubby cover, gave me one too.
Splice in the tailgate script from an AD truck.
Aw, you know me... can't pass up a chance to crack wise. Beautiful part you made there, so far, and you certainly did develop the cubby concept with grace.
The Following User Says Thank You to idrivejunk For This Useful Post:
  #216 (permalink)
Old 01-01-2020, 03:36 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Thanks Laddie.
That script looks pretty good. The purists could have a double heart attack with me cutting it up and then adding some nice Chevy swag all around it....ha....
The PO emailed last week and doesn't appreciate the direction it's going. Oh well. He didn't have me fill a questionnaire before selling it. Sorry Jim, in case you're following along. You will love it when finished, promise.
Got the firewall chunks bent up this morning.
ID:	450885   Click image for larger version
ID:	450889   Click image for larger version
ID:	450891   Click image for larger version
ID:	450893   Click image for larger version
ID:	450897   Click image for larger version
ID:	450899   Click image for larger version
Gearhead Poppa (01-01-2020), idrivejunk (01-01-2020), NEW INTERIORS (01-03-2020), Too Many Projects (01-01-2020)
  #217 (permalink)
Old 01-25-2020, 10:25 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
I believe the question of my sanity, which I'm sure you all have been ponderin' all this time, has been answered. I'm nuttier than a fruit cake.
I mean, who does this???
ID:	451343   Click image for larger version
ID:	451345   Click image for larger version
ID:	451347   Click image for larger version
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (01-28-2020), idrivejunk (01-25-2020)
  #218 (permalink)
Old 01-25-2020, 10:30 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
IDJ says to toss in the wiper motor....good idea. How about toss in a helping of cruise control while I'm at it? Need to pull on the top of the gas pedal though, rather than the throttle body, to eliminate one cable. Only want the throttle cable showing.
ID:	451351   Click image for larger version
ID:	451353   Click image for larger version
  #219 (permalink)
Old 01-25-2020, 10:31 AM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Forgot to mention, the flat area on passenger side, I can bolt up the AC unit easily to.
  #220 (permalink)
Old 01-25-2020, 12:28 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
Dang fancy, but how do you access all the "stuff" in there later ?
  #221 (permalink)
Old 01-25-2020, 02:26 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
There's the nuts part. Set up a scaffold across I guess.
Pop off the cover and reach/bend....
  #222 (permalink)
Old 01-25-2020, 03:00 PM
Would it be more accessible and worth the time/effort to make a removable panel on the inside ? You could use Dzus fasteners and foam seal tape...
  #223 (permalink)
Old 01-25-2020, 04:24 PM
idrivejunk's Avatar
Grand Prix User
A man with a plan but no bran? No cereal boxes. Perhaps call it a belfry rather than cubby?
I see silver box and black box, whuts whut?
Bright thinking. Access from both sides for sure on driver's side
How about putting it all in a crisper drawer or on a lazy Susan. Make it like a merry-go-round in there.
Man who live in glass house dress in basement. Man who want everything hid pay with impractical access. At the sketch phase I figured wise man leaves reservoir hanging out under the cover so you can at least pour.
Pugsy, just keep your far thinking hat on. Horse goes in front of the cart. I missed a weekend of V8 and hence am going Grape nuts. Just got warm enough to prime the carb though.
Accept IDJ ideas at your own risk. No running at the pool and junk.
  #224 (permalink)
Old 01-25-2020, 04:27 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
Gawd no. This whole exercise is to not have to deal with going under the dashboard. Working within the interior of a car is my worst nightmare of all repairs.
The Following User Says Thank You to 123pugsy For This Useful Post:
  #225 (permalink)
Old 01-25-2020, 04:32 PM
123pugsy's Avatar
Purists Hate Me
Wiki Edits: 29
It's all silver. Thin aluminum panels as templates. Easy to cut with snips. I will go to work in the morning and cut some stainless.
Access is tough, well, tough for me I guess. This is the insane part. Remote fill may still be in the cards for the master.
